Spark
gregjo1948
diesel 5.9l
2001 Dodge Ram 2500 Cummins diesel--Harmonic vibration damper bolted to the front end of the crankshaft has spark jumping to the edge of the oil pan. It's less than 1/4" between the two items and the spark is random, about 15-20 seconds apart while the engine is running at an idle. I'm thinking it might be needing a ground replaced somewhere. Any ideas would be appreciated. thank you, gregjo1948
G
gregjo1948
diesel 5.9l
Replaced the damper and the spark is gone.
Daw14
South Florida
You should probably clean Every ground you can find. If you doubled up on a couple it will not hurt anything. Imo you cannot over do it grounding things.
