Sport/Express Front Bumper with Tow Hooks?
BDWebb
East TN
Anyone ever seen the one piece bumper with tow hooks? I want to do a sport front end conversion and retain my tow hooks if possible.
Any advice is appreciated!
Cableman
Longisland
Atcer2018
Virginia
Yes, there is a YouTube vid on a 4th Gen tow hook install where the guy shows how he installs front tow hooks on a one piece bumper Sport.
Search YouTube for: Installing Factory Tow Hooks-Dodge Ram Sport-4th Gen.
Daniel Ortiz
Cypress, TX
5.7 L Hemi V8
@BDWebb , I've seen some really intricate, painstaking work done to carve out JUST the right sized holes in the plastic fascia for the tow hooks to slide through, like a perfect-fitting glove. Then there's my approach: :grd:IMG_20210921_073314888.jpgIMG_20210921_073413063.jpg
I think my trim piece is still in my garage lying around somewhere.
Georgiasport
Douglasville, Georgia
Hers my tow hook and light bar install. I had to fabricate tow hook relocation brackets and also brackets to mount light bar to hook brackets.
Daniel Ortiz
Cypress, TX
5.7 L Hemi V8
Those hook relocation brackets were pretty cool, and hats off to the guy that first fabricated those and gave out the design. @Georgiasport , I'm not sure if those are the ones you're using, or if you made your own, but they look good!
@BDWebb , if you do choose to use those relocation brackets, just know that by re-aligning the hooks off from the centerline of the frame rails, you're inherently lessening the strength of the hooks to transmit the full force of a dynamic recovery from the hook to the frame. By how much it's hard to say, but if you plan to use the hooks for any serious recovery operations (if you plan to get good and stuck while 4x4ing and then get yanked out), I wouldn't use relocation brackets. I'd bolt the hooks right to the frame where they were intended. However, if you don't really plan to ever be using them for serious recovery, the relocation brackets do exactly that, they center the hook into the larger opening that the sport one-piece bumpers have. And I'm sure they'd still be strong enough for a flat or static tow. Just no yanking at them.
SouthernBornRebel
Tulsa, Oklahoma
all kinds of options... front hitch, portable winch cradle, use hitch with tow hook, use snow plow.... with this type setup...
B
BDWebb
East TN
Thanks for all the info! After looking at how much it’s going to cost to do a front end swap, I think I’ll just stick with my two piece lol. I didn’t realize I would need $1,000 plus in parts to make this work lol
danielmid
Southeast WI
2015 Sport 4x4
