Squeaking door
Mike_Rut
Reidsville, NC
3.6L
My driver's side door has a loud squeak when opening or closing. I've sprayed lubricant on all the moving parts around the hinges. It almost sounds like the spring itself is making the noise. Any suggestions?
co-pilot
houston,tx
Maybe do a search......I remember reading about the same problem......sorry i'm no help
bigdodge
Pretty typical. It's the bushing in front of that spring. Best lubricant I have found to quiet it is fluid film. Other oils don't last as long.
Slickity79
Video is spot on, I actually used some Superlube from Harbor Freight. You can actually slide the roller up and down with pliers to get it under it. Worked great
twooldfarmers
SK and AZ
2014 Laramie Crew 4x4
I have the same sqwaunk and I keep a can of aerosol grease in the door for safety chain quick links and the likes and I try to hide down the spring, the roller and the door stop link ... to no avail. Just a horrible noise. Drives me [emoji529]
Sent from my CLT-L04 using Tapatalk
brny67
OBX NC
tiniest can of fluid film I've ever seen!
that would be handy to keep in the truck and on my atv
where did you get that?
A friend of mine gave it to me years ago when they first came on the scene, he had several cans. I think someone else gave him all those cans.
seabrook
seabrook
Black 2018 Night
5.7 3.92 anti slip
I like fluid film use it on my jet ski but man it smells like ass!
Iron Outlaw
I sprayed mine with wd40 months ago and it is still working.
crackerjack1957
2014 Sport 1500 CC 4x4
Hemi 5.7...65RFE...4.56
Used 2 years ago & still no squeak.
