Stereo build
smokedbystang
Central Florida
2012 Ram 1500 Express 4x4
I'm sure there are many different opinions on which speakers are better than others but I think want to go with Kicker. I've read they sound great and I'm not looking to spend a lot.
I currently have a 2012 quad cab non alpine. I have an S160 Android radio for a head unit.
My questions are: Should I go with KS or CS 6x9 speakers both front and rear doors? And 2 way or 3 way? Dash speakers KS or CS? What Amp size/brand to power them?
Eventually want to add an amp and single 12 in the back.
Thanks. I'm new to building a stereo system. Looking for clarity with some boom. Haha.
adrianp89
Tampa Bay, FL
Do components in the front instead of a 6x9 and 3.5.
Go CS if you don't plan on putting them on an amplifier or KS is you plan on amplifying them.
smokedbystang
smokedbystang
Central Florida
Not sure about components. I just want something plug and play. I'm assuming components would need the door panel modified. Correct? Or can you still put the tweeter in the dash?
JinxCanada
Windsor, Ontario, Canada
2010 Ram Sport
I just did all Kicker CS in my non alpine 2010 Ram. I did a write up and listed exactly which speakers I used. I went with 6.5" in the doors to make it easy, but if you get a 1/4" spacer off ebay you can put 6x9 in all 4 doors. I did the 3.5" kicker CS in the dash. It was a night and day difference!!! and VERY easy to do.
JinxCanada
2010 Ram Sport
I'm sure many of you have seen my recent posts asking tons of questions about speakers and subs...and I appreciate all the help and information.
I thought I'd give you all my initial impressions and feelings on the upgrades I've done so far. I installed Kicker CS 3.5" in dash, 6.5" 2 way in the doors, and 6x9 3 way in the rear doors. I was replacing the basic stock speakers (non alpine) in my 2010 Ram Sport and I have to say WOW!!!
The stock speakers were unbelievably cheap crappy junk to put it mildly. I have heard the Alpine systems and they are much much better, however, for the price the dealers charge I'm not sure I'd go that way rather than just doing aftermarket but that's just me.
so...here goes!!!
The biggest difference I noticed right away was the 3.5" 2 way speakers in the dash. To be honest I wasn't even aware I had speakers in the dash prior to this (I thought they were just vents lol) because I'd NEVER heard them before. Well...I put in the Kicker 43CSC354 and holy hell they were in your face and alive! I will say I had to turn the treble and midrange down to about 4 on the stock MyGig deck as they were way too bright...but at this level they sound great, clean, crisp, detailed and the highs are amazing and alive!
https://www.crutchfield.com/p_206CSC354/Kicker-43CSC354.html
Now on to the front doors. I really thought I'd be able to fit 6x9 in the front doors....I mean why not they fit in the back right? Well there is a steel bar in the front door that prohibits a plug and play 6x9 solution. That being said I'm sure with a small shim you could probably fit them. That being said, I went with the 6.5" 2 way Kicker 43CSC654 as suggested by Crutchfield and I am very pleased. Using the provided 6x9 plate adapter it was an easy installation and they sound great!
https://www.crutchfield.com/p_206CSC654/Kicker-43CSC654.html
In the rear doors I replaced the stock 6x9 with Kicker 43CSC6934 and adjusted a bit more of the sound to the rear of the truck take a bit of the load off the 6.5" and round out the sound. Well these speakers give a lot more bass than I would have expected and sound amazing. I do plan to add my 2 subs to the truck...but that will come later/soon.
https://www.crutchfield.com/p_206CSC6934/Kicker-43CSC6934.html
In summary I expected better sound but quite honestly I really didnt' expect the level of clarity, life, detail, and truck filling sound experience I'm having now compared to the stock speakers. I am still using the stock MyGig 20gig hdd head unit and it powers these speakers easily. The best part was the included free plug adapters from Crutchfield. This made the installation so easy as I never had to cut a single wire. It was truly plug and play!!!
If you have a base stereo in your truck, you OWE it to yourself to spend the $156.00 USD I did and replace all 6 speakers. You will not believe what you've been missing. I honestly can not say enough good things about the quality of these Kicker speakers, the service I received from Crutchfield, and the satisfaction I now have with a stereo that sounds IMHO better than my buddy's Ram 2500 Limited with the Alpine system in it (minus the bass which is coming very soon) for so much less money! :)
I guess that's it for now...i'll report back once I get my dual 10" subs installed and running...but I expect to have a perma-grin on my face even more than I do now. Thanks for reading!!!
smokedbystang
smokedbystang
Central Florida
Yes I saw it. That's why I'm going with Kicker! Haha. Just wasn't sure if I should go CS or KS series. Or 2 way or 3 way. I'm sure I'll be happy with either though.
adrianp89
Tampa Bay, FL
Tweeter can go in dash. I say components because it will sound much better. Even the user above had to use resistors to tame the 3.5s. Component is the way to go, and install isn't that much more work.
JinxCanada
2010 Ram Sport
go with 4 of the 43CSC6934
https://www.crutchfield.com/p_206CSC6934/Kicker-43CSC6934.html?tp=91
and then order the 1/4" adapters off ebay
https://www.ebay.com/itm/6x9-Speake...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
I actually just arranged to return the 6.5" kicker cs that I had ordered and am going to do the same thing...put the 6x9 in the front doors (as was my original plan)
JinxCanada
2010 Ram Sport
yes the 3.5" in the dash are a bit of a beast...and I'm not 100% sure I'm done with them. I might even clip the tweeter wires inside the 3.5" so they are just a mid bass driver instead. They are that in your face...but again...it's a work in progress.
Witch
Hemi 5.7 liter
They will only knock down the HZ to around 600 ish and below I think ?
