Strange noise.
rcarbaugh
Conway SC
Okay guys and gals. I have a 2014 Ram 2500 4x4 Cummins. I am having a strange noise she slowing down. It’s coming from the front of the truck some where. The only way that I can discribe it is like the noise that a flat spotted tire makes. I have checked the front diff fluid level and it’s good. This is my first 4x4. So with that being said I can rotate the drive shaft and it makes noises. I would say popping but maybe a “ping”. I am also able to move the front driveshaft just a small bit. Any thoughts or suggestions?
Addicted2fishing
Durham region
HEMI 5.7
Well I have a 2017 1500 and the driveshaft was making noise. I brought it in and they checked it and it was fine. They reported play in it but said it was normal.
I think there may be a recall not 100% sure..... Aftermarket exhaust? Sometimes the cam hit the driveshaft.
Kap1
Ex Ram 1500 2013 owner
2022 Tundra
3.5 vvti
Take it to the dealership and try to reproduce the sound for them.
CostaRam
Costa Rica
In my 1500 i can rotate the front drive shaft when in 2x4 but this may be different on the 2500 cummins.
Chris
rcarbaugh
rcarbaugh
Conway SC
Thanks for the help. I am at the dealership now. Just rode with the service manager. He is going to have a tech ride with him to see if they can find out what the issue is. I will let y’all know the out come.
Ratket
Arizona-
The u joints can “ping” and the noise will carry down the drive shaft. Simple enough fix. Have you ever greased that notorious u joint like you are supposed to every oil change? If not I would bet it is the culprit.
rcarbaugh
rcarbaugh
Conway SC
You were very close. It was the right front wheel u joint. Fixed under warranty!! Even have a leveling kit in it.
rcarbaugh
rcarbaugh
Conway SC
Also I just brought this truck about two months ago. Not sure how it was treated befoRe me.
