Streak free glass cleaning, cheap and easy
Docwagon1776
Midwest
Warm water + dish soap + rubbing alcohol. Nothing expensive to buy, easier than Windex or any glass specific cleaner I've bought.
We made a small bucket's worth and cleaned our sunroom windows, then I did our three vehicles inside and out. Works like a champ.
FredC
CA
6.7L diesel
FredC
CA
6.7L diesel
What if the inside has a film to reduce light/ heat ?? Will the alchohol damage it ??
CGilham
SC
3L Hurricane
most likely. I was told not to use any alcohol products on mine. Sprayway is what I like to use.
Wonder how it'd work if you put it in a spray bottle?
Docwagon1776
Docwagon1776
Midwest
Other than length of time spent, I figure it'd be the same as long as you sprayed it on heavy vs just a misting. I think part of what makes it easier is just the amount of liquid you're working with. Having a lot of really slippery solution makes the cloth glide along the glass really smoothly without having to 'scrub' at all.
Alweeja
It is all about the application choice. Choosing correctly will create the End Results you want.
Knowledge is Power.
Gary Fields
Houston, TX
Try using Chemical Guys glass cleaner. It actually works and does not streak. Casts more but does the job. Wally World or Azamon.
TMFMK
