CoreySinger
https://www.amazon.ca/gp/aw/d/B0050Z1SJC?psc=1&ref=ppx_pop_mob_b_asin_image
Maybe shop around a bit. I didnt pay that much a month ago.
Do you happen to have the model number, as we all seem to have the same kit?I didn't use Durango bags on mine I used a measurement method to order mine from the sized ones they got. And bags won't really lift the rear when aired up. They stiffen the ride for hauling. I run 5 lbs in mine at all times. If I run 10-15 without a load it's super harsh
how low can we go in the front of these 4x4. and how does everyone truck ride like with the 2/4
Anyone else have the belltech 965sp kit and want to show a pic or tell about your joys or sorrows?
I didn’t mean you silly. I already know all about yours!
I put the SRT replicas on a couple of weeks prior to the drop. I don't know if it is the setup or the wheels and tires but I have a flutter bounce feeling from 55mph - 70mph range. The wheels and tires have been balanced multiple times and I think its a bad set of Nittos. I have to go back to get them looked at one more time then filing a warranty claim with the vendor where I bought them from. From all the posts I've read about Belltech, it should not be doing this.
I also have somewhat of an install thread if you search for it. Its more of a post of all the problems I had during the install.
I think tht's the kit I used?Did anyone use the spring insulators out of the 91213 groundforce kit or stick with the stock ones? Just curious
Then, I used everything that came with the kit.Yes it is
