Strictly the 4x4 lowering thread...
dracman
canada
2017 black out edition
anyone have this happen think gonna cut factory bump down and try that .if that don't work off go the bs cups l
Yamanube
Cut the factory bump down so it it locks into the cup with the bottom groove, that should be enough.
dracman
canada
ya just did it today.hows every ones truck drive like
dracman
canada
Here’s some pics. And this is a 2/4 kit hate to see any lower. But then guessing bs cup holder has to be taken off
dracman
canada
whats everyones 4x4 drive like after your 2/4 drop.and can ya drop some pics.
dracman
canada
Just inquiring...
Soooo... I currently have a 2/4 drop on my 4x4. I am really considering an inch lower all the way around. I know I can't really cut much off of the front due to the pig tail coil. My question is has anyone removed a .25-.50 coil from the bottom of the front coils? If so results and opinions on ride and will in cause any cv issues. If so its a no go. If in the clear I think it's going to happen. Thank you in advance for any advise
what size wheel and tire .looks wicked
dracman
canada
Ok so gave it time to settle it’s a 1/2 lower in the back. Shouldn’t it be a inch higher in back for the rake look.bell tech 2/4. 4x4. Need some help it’s ******* me off. Lol
H1Chester
My Belltech 965SP just showed up on Monday! Installing over the holiday!
Midnight Storm
One Badass Ram
Victoria, B.C Canada
I’m looking for more info on air bags for my 16CC 4x4. Not helper bags... press a switch and drop it 6” kind of bags!
Not doing too well with internet searches. Mostly just helper bags and stock air ride stuff comes up.
H1Chester
Great little thread man. I might go that direction now. Even though it was a challenge, you probably appreciate the looks that much more now :D
Yes I am pleased with it so far. I get a lot of looks! If you decide to do it, it is definitely doable but I would for sure have a buddy help you. Also as with everything having the right tools, a plan and the time to do it is critical!
dracman
canada
can some of ya guys take a pic of how much room ya have on rear bump stop to rear end.i got bellteck to sent down another set of rear drop coils cause mines lower in rear.she said they tested them before they shipped them i put them on yesterday with there shocks and still the same.still sitting on rear bump stops.i don't know what to do.need your helps guys
predat-r
4.7 v8
Can anyone tell me the true amount of drop the GF 9983 kit will have on my 15' RBSC? does out truly get and stay level? Or just a little rake?
Quote not enough I have front springs from GF and I'm cutting them! 2wd front spindles helped with lowering the front but I'm off jus a lil bit.
Sent from my SM-N920P using Tapatalk
predat-r
4.7 v8
I've been enjoying the lowered life.......little different than I'm used to!
Ride isn't too bad on the GroundForce 9984 kit, little stiff, but all good for me.
Can't see any pics!!!!!!
Joey93
