Struggling between Morimoto and Alpharex
Potatoe
Colorado
Cost no factor. Just want plug and play, low issue, improvement for crappy (being kind) stock headlights.
Research shows both have issues but no clue on how bad they are? Pretty confused on better option.
Leaning Alpharex Nova
2013 laramie longhorn.
bm02tj
B C Canada
as far as I know Morimoto is only one that has DOT SAE showing on the lens
when I asked Alpharex I was told no I went with Morimoto Hybrid at $1250 CAD
so will be cheaper your side of border
JC4041
Rosamond, CA
There's a few of us on here that run the dual projector AlphaRex's. Got mine on amazon for less than $300.
hunterdan
SE PA
2019 classic
If you go alpharex, go for the lux or nova with the dedicated led projectors instead of the pro series. By the time you add quality led and/or hid kits to them, you're almost paying the same as the dedicated led projectors.
P
Potatoe
Colorado
Hybrid seemed like a good option. Was seeing warnings that they don't work with factory projectors?
JC4041
Rosamond, CA
Mine was a single bulb (dual bulb)
These are the "factory projector" trucks
Nick@GotExhaust
Supporting Vendor
SC
Our customers like both brands. No real complaints on either brand.
let us know if you would like a quote on either as we offer both. Send me a message for information and pricing.
P
Potatoe
Colorado
I can get Alpharex Novas at O'Reilly auto which if issues makes for easy returns.
Justin33
Is that really worth it as it’s not a replaceable bulb and built in chip?
hunterdan
SE PA
2019 classic
In my opinion, absolutely. A projector designed solely for an led is going to give you the best output. Replacement led bulbs have a weakness, and that's heat. They ALL lose output as they heat up until they get to their operating temp. A housing designed around an led chip is going to manage that heat better and have a more stable output.
Justin33
So which version has the chip… I’m so confused on all the different versions. Busy at work but it looks like I could even do alpha Rex fifth gen on my fourth gen if I wanted correct?
hunterdan
SE PA
2019 classic
Luxx and nova have built in leds. They have a ton of different styles available, just pick the style you want and look for luxx or nova.
