Sub Questions
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
Still check voltage, it could still be power wire is insufficient.
G-Ride990
Administrator
Chandler, AZ
5.7 No E-torque
Caps are kind of like a shock absorber on your suspension smoothing out your ride. When your electrical system can't keep up, it will help smooth out the power delivery. They are not a replacement for nicer batteries and power wires and good grounding.
FYI, I am running three amplifiers in my stock charging system and have zero headlight flickering. I have a big 3 upgrade and a nice AGM battery.
marshall634
marshall634
Deerfield Beach, FL
2019 Classic
Whats the big 3 upgrade?
G-Ride990
Administrator
Chandler, AZ
5.7 No E-torque
You will replace the following three connections with large gauge 100% oxygen free copper wires, Battery negative to chassis ground, chassis ground to engine ground and alternator charge wire to positive battery.
rotwiler
Washington
Good ground can work wonders. I run a soundQubed amp that at 1 ohm runs a steady 1150 ish watts and around 1600 when bass hits(is what amp dyno showed) powering 2 kappa 1200w subs(12 inch) and have the stock alpine amp running interior and no electrical upgrades and even turned up to clipping I get very little light surge. Also running 2ga pos and 1ga for ground.
Barney556180
Don't need no stinkin' mask...
Northern Michigan
Huh...can’t hear ya over the music [emoji33][emoji444]
cam101
NC
I would upgrade your amp wire from 8 guage to 4 guage. As far as your lights flickering just get a larger battery and that should your flickering issue.
DJack
