Superchips Vivid Paq
S
SilsHemi
So really what does this do different than the previous superchip besides having the monitor screen.
Edit: 3,800th post!
Erik,
It will do a lot more. Check it here: VIVID Performance Tuner
If you're good with what you have, you won't need to change. Tuning files are the same. This fills a gap for those folks who want all the real time stuff displayed on their dash. The trans tuning app will give you graphics as well. Sort of like the excel files we use now.
I'll post some of what Scott sent me later.
Sil
EJM05
Somers, CT
440 Big Block
SilsHemi said:
Erik,
Sil
I currently don't have a tuner. I want this one but need some $$
S
SilsHemi
This was from Scott via e-mail:
I believe you guys are gonna love the way we have redone the Advanced Trans tuning app. It is much easier to use now that we can employ better graphics. Here are a couple screen shots:
The Shift Point adjustment feature offers the following features:
1) The main graph details each shift point line and how it performs by MPH vs. throttle position.
2) The two grey buttons in the upper left hand corner of the screen allow you to view and adjust your up and down Shift Points individually or together.
3) The color coded lines detail each shift table. By touching one of those lines you highlight that particular shift point on the main graph allowing it to be adjusted.
4) The Points tab allows you to view your adjustments by numeric value.
5) The Shift Groups tab switches you between street/strip (warm) and offroad/crawl (low) tuning.
Shift Point adjustments are made by identifying the color coded schedule that you would like to adjust from the column to the left. With your finger touch any one of the intersecting dots in the graph and drag the dot to the desired location.
The user can also adjust each shift point by numerical value in the Points tab.
Similar to the Shift Point adjustment feature, the Torque management (Shift Firmness) feature for Dodge gas trucks and SUV applications allows you the ability to adjust how firm your gear up and down shifts are. Here is a definition of the product features:
1) The main graph details torque Management lines for each gear change and how it performs between pedal percentage vs. RPM.
3) The color coded lines detail shift torque for each gear change at part throttle. By touching one of those lines you highlight that particular line on the main graph allowing it to be adjusted.
4) The Points tab allows you to view your adjustments by numeric value for both part throttle and wide open throttle torque (Part throttle torque is shown by default).
5) The Shift Groups tab allows you to switch between part throttle torque and wide open throttle torque allowing you the ability to tune both.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
I has some pics!
I have a universal mount in the truck - which fit this perfectly!
Only goofy thing so far? "DOD"
What the hell is "DOD"........derrr.......Displacement on demand.
Scott - have 'em change that to MDS. :D I was scratching my head! :D
Ramunit
While they're at it tell them to change the image of a Ford to a Dodge truck.
LB3711
Trumbull, CT
3.6L V6
You still suck
Sent from my Transformer TF101 using Tapatalk
ramhunter9
P-Star Jeep Wrangler
Pretty slick deal for the Hemi
And Sil .. Good to hear from ya bud
truckin151
2013 sport
That looks f*ckin. Sweet!!!!!! BUT YOU STILL DON'T DO CUSTOM TUNING!!!! I would switch if you did custom tuning
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
More pics from tonight's tuning
Torque Management - WOT settings
Setting the tranny for my shift schedule:
Pretty slick tuner!
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
oh, the best part?
I tuned the tranny while sitting on my couch.
EJM05
Somers, CT
440 Big Block
ramhunter9 said:
Just get a CTD already .. Dam Son :Grenade:
Here's the deal... I'm gonna have my mom sell my Ram while I'm over seas and once it sells on gonna pick up a 2006 5.9 and have my buddy who is a CTD mechanic work on it in his dad's shop while I'm deployed. I'm gonna have a fully built tranny with a twin Turbo. I'm gonna make a speed demon.
Thread Jack over.
noraa73
