If most people filled their cars' gas tanks with 98-octane fuel, the United States could cut annual carbon dioxide emissions by up to 35 million tons and save $6 billion a year, according to research from MIT.
Current octane ratings typically range from 87 (regular) to 93 (premium). But, the researchers surmised that if the U.S. were to adopt a new standard, making 93 regular and boosting premium to 98, it would change the way cars are manufactured, leading to more efficient vehicles designed to run on higher-octane fuel, which would result in a massively reduced carbon footprint within the next few decades.
It's not a simple equation of higher equals better. In fact, it's a fairly common misconception that shelling out extra for premium -- a splurge even with
gas prices as low as they are -- is always beneficial. It doesn't clean the engine or increase mileage or performance. Car engines have their own octane numbers, meaning that they are specifically designed to run on a particular grade of fuel, usually regular. So filling with a higher grade won't help, unless your car is built for it.
Unfortunately too many people are over eager to shell out hard earned money over what they heard FROM A BUDDY and or falsely believe concerning higher octane fuels, like for instance "93 octane turns my truck into a speed demon!"...Yeah, sure!...HAHAHAHAHAHA...AND IF MY GRANNY HAD WHEELS SHE'D BE A WAGON.
The 5.7 Hemi from the factory has a horrible pollution rating based upon EPA findings. Because of this the MDS System along with a few other systems were implemented onto the vehicle to help deal with the pollution issue. Some believe the MDS system was created to improve the mileage of the vehicle. That is not true, that is simply a welcomed byproduct of the system. Myself, I personally found a gain of around 2mpg by deactivating the MDS system on my 07 RAM 1500. 7500lbs is a lot to be moving around with only 4 cylinders. When in MDS mode, the Hemi 5.7 opens the injectors to increase fuel flow. They will remain in that state until there is the requirement for the other 4 cylinders to engage. There is a LOT out there that people simply do not know about their vehicles. Too many myths and fables, false beliefs being passed along as truth.
