Thick oil is thick oil, if you were expecting 5w30 redline to be thin at start up you should change those expectations. I'm not saying you in particular but you know what I'm say'n. It would be similar to a 40 weight in the cold, but yes of course will pour down to lower temps then group 3 stuff. Thicker oils are thicker all through the temperature spectrum, not just operating temps. In the cold the difference can be huge between a thick 30 weight and a thin 20 weight. Like those oils are pretty similar at cSt, but in the cold the difference can be 250-500 visc. So it was disappointing to hear this issue came up, but the science sure backs it up. If there is an answer for this cold piston slap, I personally think it will be 0w20. If 0w30 works, then winner winner, it is like the best of both worlds.
Here's a question, is that 180 t stat keeping oil temps down? If it is, then a simple t stat can turn 20 weight into a 30 weight in the crank case. Something else to consider.
