I put a Duralast AGM H7 in my truck about 3 years ago when the factory battery crapped out. So far seems to be holding up well.
Next time I'm going with a H8. Its slightly larger but will fit in the factory battery tray with a simple mod. They have more CCAs and are ironically cheaper than H7s in most cases...
Gents, let’s talk batteries for a minute.
For those what have replaced their factory battery, what did you choose and why?
2018 Ram 2500 6.4L 4x4
Amsoil SS 0W-40
Walmart. Agm h8. Higher cranking amps. Higher constant draw rating. 4 year no questions asked replacement. Cheaper than the auto parts stores by about 50$Gents, let’s talk batteries for a minute.
Amsoil SS 0W-40
Moes sells them. Lithium and heat don’t like each other so I’m not sure how they will doAnyone thought about going to lithium?
Amsoil SS 0W-40
Amsoil SS 0W-40
I haven't looked at it yet, but I think it was @crazykid1994 that posted about knocking a part of the tray out so the H8 would fit. I do know there's about an inch of extra space in the battery tray with a H7 battery there...The Durango and probably you old GC take the H8 size.
What’s the mod?
Amsoil SS 0W-40
Lithium loses a LOT of amperage when its cold. When I'm at work this time of year i have to move my cordless drill to the cab of the van so it will warm up and actually work.Anyone thought about going to lithium?
Amsoil SS 0W-40
So it does fit in the tray and the terminals reach?I put an Odyssey 49-950 (H8) in mine in the fall.
It looks huge in there compared to the stock one.
Average lifespan for a normal battery is 3-5 years.
The average lifespan for an Odyssey is 8 years.
That would be the factory H7 replacement for the gasser trucks and CTD(times 2). As mentioned above the 49-950 is the H8 size which is standard for the EcoDiesel, should fit the gasser trays.Odyssey (AGM), made in USA. 94R-850. H7 size
