Since we're on the subject of trans fluid, might as well let you guys in on an experiment I've been doing. Back in November I decided to try Amsoil SS MVATF in my 65rfe. I had emailed them to get in writing that they recommended it in case my trans grenaded. They assured me it was OK so I had it in writing. I had previously used it in my tcase with great success but I had never really paid much attention to it besides the Easy Pack and how easy it was to fill the tcase with it. It has that unique ATF+4 smell to it too which surprised me seeing as it supposedly meets many oem specs. I put it next to so ATF+4 and C+ I had and they literally smell identical. Obviously not scientific but I figured I'd mention it.
So I did 2 drain and fills with a drive to operati g temp in between and waited for a shudder or check engine light or limp mode. Nothing. It shifts exactly the same as with C+ or ATF+4. I might even say it shifts *slightly* better under WOT than C+ but there could be many variables with that. Honestly I'm extremely shocked and impressed.
We have our first camping trip planed in a couple weeks so I'll definitely update on towing with it but as of right now I wouldn't hesitate to use Ss MVATF in your RFE or the Fuel Efficient ATF in your ZF8.
Like
@Burla said, maybe we need to be less brand loyal and focus more on formula and performance. If towing with the MVATF is as good as C+ I'll likely use what C+ I have a stock of and switch over to MVATF as it's a bit cheaper than C+...
