I’m at a bit of a quandary with my 2019 classic Hemi. At 33,000 miles I changed oil with Royal Purple 5w30 and an RP filter. This was the result:
About 3,000 miles later the oil pressure slowly dropped fro 48 psi to 42 and even 41 psi at times:
Certainly I checked the oil level and outside temp was 20 degrees colder with the lower pressure.
Many folks say that hiway pressure is over 50 psi….I’ve never seen that.
It concerns me that psi dropped 7-8 pounds over a 300 mile run with oil the only has 3,000 miles on it.
Any ideas?? Oil break down? Pressure sensor going bad? Engine about to grenade?
