The holes are not the only variable though so experiment is flawed. The media and design differ enough that holes cannot be one and only factor.
Flawed , maybe . There are many variables .
For me it really just wasn't about the Qty of holes alone , my test was ultimately filter to filter , regardless of any one individual diff experimenting for since the results was ZERO difference between the two filters then all differences between the two filters are pretty much +-0.
For me the experiment was complete enough , for I wanted to know if the Wix Xp would have any pressure drop over the RP 10-48 on my current oil fill under the same conditions & parameters , and the final results (less a cold oil start up ) was Zero differences .
☆☆☆☆☆☆☆EDIT☆☆☆☆☆☆☆☆
As promised cold start / first start of the day oil pressure with the Wix Xp .
OAT = 61°f
Max high idle rpm = 1450 approx.
Max indicated oil psig=58
Continued pressures on my way to work , I started recording the pressures once the oil Temp was @ 200°f , max oil temp once I got to work 206°f.
55 mph flat ground = 52 psig
65 mph flat ground = 55 psig
75 mph slight + grade = 57 psig
Idle in park 206°f oil temp = 43 psig
These #s are essentially identical to the RP10-48 Filter as expected .
These #s are within 1-3 psig of when I ran the PYB 20 wt oil as well .
With the 20 wt PYB the cold start high rpm idle would be 61 psig at times ? Other times 58-59 psig , the rest of the #s with the 20 wt PYB wer just a tick lower on pressure 1 - 3 psig , thus indicating a bit more flow
So in conclusion as far as the Filter comparison goes Zero differences.
As far as the oil wt goes ( based off temps and pressures ONLY )
Not enough of a difference in flow to convince me to lessen the added film strength I'm getting using a heavier wt oil than the recommended 20wt .
My oil 3ea RL 40wt , 4 ea RL 30 wt which computes to approximately a 33wt oil (if you believe in a sliding scale ) maybe maybe not ?
I also feel it's important to note my MDS works the same with 20wt & my 33wt oil .
I've had Zero issues , my engine is stock less an occ and drop in air filter .
Some seem to be concerned with mpgs , I've notice no change at all , but logic tells me a 20 wt should get a little better ...
I drive like a blue haired grandma most of the time I avg year round about 19 mpg , right now with higher outside air temps my last two tanks I'm averaging about 21.0 .
I hope my experiences with my personal experiment has been informative and helps others make a more informed decision for their spacific wants and needs for oil & filter in truck .
We all operate in diff environments and we all have diff needs , remember it seems diff Rams 5.7L seem to be different as well .
Good luck with your truck !
