Synthetic Oil
Oil of Choice
  • Castrol Syntec/Edge
    Votes: 237 8.5%
  • Royal Purple
    Votes: 327 11.7%
  • AMSOil
    Votes: 401 14.4%
  • Valvoline Synpower
    Votes: 161 5.8%
  • Mobil 1
    Votes: 1,000 35.8%
  • Other
    Votes: 664 23.8%
  • Total voters
    2,790
james.price.58
U.S. Navy Veteran
Yeah, I was debating the Fram, but someone earlier on the thread mentioned they were pretty good.
U&A
2016 3500 SRW
6.4 HEMI
Its a great filter.
See Burla’s oil filter thread that is in his signature.
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Seriously,
Try the tractor supply bar oil. You will save money and it works perfectly fine. Winter formal...I add a little less than 1/2 quart or so of NEW 75-140 gear oil (cheapest i can possibly find) to a 1 gallon container of bar oil. Thins it out a bit for the cold.
I didn’t buy it inherited it when my uncle died. We have had those jugs for years. It lasts a long time except these Stihls always seem to leak even when you tighten with the tool!
U&A
2016 3500 SRW
6.4 HEMI
Stihl is known for that. They leak when sitting
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Probably 2nd best!
I am considering the EA from Amsoil and The RP the same as they basically are. Otherwise we shall give it 3rd place.
Zack02
Yeah you can run it, there's been varying results with it tho. @Burla didn't have a good experience with it but @R.L.K. had a great experience with it....
Lol, I meant in the saw.
Here she is sir. Looks like its the “MAX”. I could be misinterpreting this but it seems the Hercules possibly has a much better battery.
Yeah, that's the "MAX," the "Max" is brushless. I'm not sure if they could make it more confusing. It reads like a better battery, but I would like to see some to some real world tests. I don't trust HF :)
Yep, as @U&A said. Mine leaks, I believe there's a bulletin for a fix, like a little plug in the front.
Probably 2nd best!
EA has less holes on top x2, a little disapointing imo. If RP stops making them, I still think EA would take top spot from what we know currently.
U&A
2016 3500 SRW
6.4 HEMI
Id have to skip the EA. Id be an emotional wreck using a filter with such few holes[emoji1787]
Id jump right to the FU
U&A
2016 3500 SRW
6.4 HEMI
Nice looking truck. Burla and I LOVE stock rims and aggressive tires.
You planning 2 trans fluid changes obviously? Your diffs have gaskets or you using RTV? Aftermarket gasket?
AFMoulton
Nuevo Mexico
DUDES!!!! Houses are expensive! Sorry I’ve been absent lately but been busy nailing this down! We move in either the 14th or 15th!
And we just bought $5k+ of shot for the house.....now if only I could squeeze in some truck stuff!
2018 2500 6.4 4x4 4.10 Amsoil SS 0w-40, Softopper
Black Rhino Armory 18x9 +12mm
Cooper St MAXX LT295/70R18
2016 Durango 5.7 AWD 3.07 Amsoil SS 4 Qts 5W-30 and 3 Qts 0W-40
1996 Nissan Altima 2.4 Amsoil SS 5W-30
AFMoulton
Nuevo Mexico
Congrats Jeff.
Thanks Mike!
