Tail light plug
Charles Gagliano
5.7L HEMI
Trying to locate the plug for the rear tail lights on a 2015 1500. Not the socket that the light plugs into, I need the actual plug that is part of the harness. There seems to be a loose wire in mine causing the brake and turn signal to not work. Although the running light works fine.
jerryt
crossville tn 38572
Do they make a pig tail connector for the 12 wires that go to the igntion switch on a 2004 ram 1500?
AllMoparParts.com
- Benny
Supporting Member Supporting Vendor
All
All
Yes but its listed as a 14 way, The part number is
5183441AA
See the attached PDF diagram
-Benny
  • Mopar Connection Repair Kit.pdf
