TAILGATE weight capacity... 3/4 & 1-ton trucks
U&A
2016 3500 SRW
6.4 HEMI
TAILGATE weight capacity?... 3/4 & 1-ton trucks
cant seem to find any info on this. just a lot of guessing and personal experiences. unloading pallets with steel weldments on it always makes me cringe as the forks are never long enough to get it in one grab. you always have to pull it out half way and sick her in again... :)naughty:see avatar). joke aside,
is there an actual published rating?
sbarron
Wasilla, Alaska
And remember that your pallet will never be 100% on the tailgate. I've unloaded many pallets with steel weldments from previously owned RAMs (oilfield service) and never had an issue. If worried, distribute the weight with plywood/boards or as mentioned, take the tailgate off.
Also remember, 2000lbs of steel on a pallet is less than 2psi of displaced weight.
U&A
U&A
2016 3500 SRW
6.4 HEMI
Why not just take the tailgate off before unloading.
thats a lot of on and off.
just wondering if there is a published limit that i missed. not an alternative solution as there hasn't been a problem.
sbarron
Wasilla, Alaska
You likely won't get a published rating as there are so many variables.
U&A
U&A
2016 3500 SRW
6.4 HEMI
if thats the case
thats all I was wondering.
reloaderguy
Oregon
2016 Power Wagon
That's what she said?
PippinAin'tEasy
Agreed on the difficulty/awkwardness of the harness when you've got the camera and yer fingers can't quite get the grip you need and there's that little thing you have to flip and yer trying to pop it without tweaking the wiring....
Yep, that's what she said.
"Oh, sweet debt. Thy name is Truck."
RAM_Designs
Rockwall, TX
6.4L Hemi
I routinely put 500-600# worth of batteries at the end of the tailgate, and then step my 205lb self up at the end of it as well.
