"Tesla Style" 10.4 Android Radio Information
Fluxlicious
Belgium, WVL
Interesting. My Lockpick recently crapped out again so I have 4 cameras doing nothing right now. Does this system use any camera or does it come with specific cameras?
They all seem to come with specific cameras. I guess the stock front and rear cam can be used, side cams need to be specific 180° fisheye cams.
Verstuurd vanaf mijn ONEPLUS A3003 met Tapatalk
SitKneelBend
St. Louis
3.6 Pentastar
Thanks!
adrianp89
Tampa Bay, FL
If you stick with factory, the PAC piece is much better than the LockPick.
Also the 360 cameras SUCK to set-up. The only one I did, took two full days of adjusting to get it right.
SitKneelBend
St. Louis
3.6 Pentastar
PAC piece? I'm not familiar with what you're talking about?
pwjouster
South Florida
proabably going to look at one of these in my 2500, found someone near me who has one and its sick
SitKneelBend
St. Louis
3.6 Pentastar
You know, I wonder if this would work with this Tesla radio too? It's controlled with the steering wheel and gauge cluster, right?
guardiannite
Clovis NM
2015 Dodoge Ram 1500
I see there is rca outputs for aftermarket amps, but we still need to tap into the factory speaker wires to give sound back to the speakers?
mdifilippo
mdifilippo
NJ
If you wanted to run the factory speakers off of an aftermarket amp? Yes you would.
dearchristopher
Galveston, TX
i've been back and forth between this and the 8.4 as I have the uconnect 5.0
are you able to control the truck settings like you can in the 8.4?
How do you like controlling your climate with only the tablet?
guardiannite
Clovis NM
does it have voice activated controlls, meaning tell it to text someone or call someone..stuff like that. Is Phoenix shipping the new connector with the units or do i need to request it at time of purchase?
MLB12
Calgary, Alberta Canada
2016 Laramie Longhorn
HEMI 5.7
I'm thinking very seriously about one of these units, but before I do, I'd like to be able to have a serious read of the Installation/User's Manual.
Would anyone be prepared to share theirs with me? If so, I can provide my regular email address, as long as it is within the site rules.
All help will be greatly appreciated.
hoe...
There is no manual......
Just watch the YouTube video to install. It's a simple install.
Not much point having a user's manual as it is basically an android tablet and users will customise it with their preferred launcher and apps.
You will need to spend some time setting it up and adding apps to suit as the supplied interface is a bit bland....
I suggest you get hold of an android tablet and install a car launcher and music app etc and work out if you like it.
Remember it will run any android app, eBay, weather, nav etc.
Sent from my BLA-L29 using Tapatalk
guardiannite
Clovis NM
what mic did you use to replace the mic on this radio, and what 3.5mm jack did you use? Most require 3 wires, this radio have only 2 did you just not use the shield wire?
Goodie1990
