Brimmstone
Will do that in a little bit
Go to settings, then the more settings tab (on top) to get into the Android settings. Once there, go to the "Apps" section.Got the pic changed. Only thing that was different was password. Mine uses 666888. Now to figure out how to get previous guy signed out of google play store
I'm told Rhino Radios is a good reseller and there prices are competitive. I have no experience with them personally though.I've been holding off buying one of these for my truck in hopes the price would come down. Looks like it's going up. Anyone got links to a place with a good price?
I'll have a look. Thank youI'm told Rhino Radios is a good reseller and there prices are competitive. I have no experience with them personally though.
Stay away from Phoenix Android IMO. There service has seriously degraded over the past year.
Oh my... would love to see it installed but it looks like it's big enough to eclipse the entire center stack!Well Phoenix just announced this behemoth.. universal double din unit. Wonder if Rhino Radios will have it as well, good price, just wondering how the layout would work for allowing you to actually access the A/C controls
https://www.phoenixautomotiveinc.co...fQiSdkuXolaagPN6_6ySd5wtIo4HNIdK-uM6xueZ3Uzqk
And kill you if the air bag goes off!Oh my... would love to see it installed but it looks like it's big enough to eclipse the entire center stack!
Maybe you can help me...I can't get my backup camera to work when I put my truck in reverse,it works just fine when I manually turn it on but no luck with reverse...I've went into the advanced settings and tried Ram Hi ,lo and American but no luck...someone had mentioned on some other forum about the baud rate...when Phoenix finally contacted me about the issue, they weren't much help on the camera but did say the baud rate was for hvac...it's a small issue but it's makin me lose my mind
I was helping out someone with this issue and sadly they returned it before we could diagnose it. But do you have the GPS plugged in? Silly question I know but the person I was helping didn't and I know that was causing at least one of his other problems.Maybe you can help me...I can't get my backup camera to work when I put my truck in reverse,it works just fine when I manually turn it on but no luck with reverse...I've went into the advanced settings and tried Ram Hi ,lo and American but no luck...someone had mentioned on some other forum about the baud rate...when Phoenix finally contacted me about the issue, they weren't much help on the camera but did say the baud rate was for hvac...it's a small issue but it's makin me lose my mind
Try the PAC adapter..beats taping a fuse etc..I was helping out someone with this issue and sadly they returned it before we could diagnose it. But do you have the GPS plugged in? Silly question I know but the person I was helping didn't and I know that was causing at least one of his other problems.
Got my radio last night and installed it. It was a quick and easy thanks to this post and videos out there. Couple of things I noticed.
1. AC controls this took me the longest. The connection is very tight. My controls would not work until I literally brute force that connection. That plug has to be seated completely before mine worked.
2. Metric / imperial. When I set the unit to imperial it does work. But it sets my cluster to metric. So the opposite of what the head unit is. Am thinking I have to put the old unit back in and set it to imperial?
3. It's so slow. Response time is terrible. Even my steering wheel controls lag. I'll post a pic of my software versions. Am hoping I am running a older version.
Sent from my SM-G975U using Tapatalk
