The dreaded manifold swap
16WhiteQC
Hudson valley, NY
I have 2 bolts that are sheared at the head. The rear most on passenger side and front most on drivers side.
We were at them trying to get a washer/nut to weld on these 2 but to no avail so we called ita night.
Hopefully better luck today.
I used zinc plated hardware (all I had around) and my buddy was able to weld them up pretty easy...but he has been welding for decades.
ffeschjeff
Firefighter EMT
Tulsa Oklahoma
My passenger side wasn't to difficult i tried the washer/nut method to get the 2 broken studs i had but being i novice welder i couldn't get a good stick. i ended up getting enough of a nub built up on them to get vice grips on them.
now i gotta do the drivers side but there seems to be a ton of crap in the way on my 15.
metalmike2016
Mooresville NC
I just put the BD Diesel manifolds on. The passenger side was easy only had to drill out one bolt. I used the template with the drill guides. Driver side was a pain to say the least. Good luck to all that do this job. It is nice and quiet now.
You probably know this,but are you disconnecting the battery before welding on the truck.
PhilipElder
Canada
My grey matter is a bit dull but I seem to recall a method where one started and heated up the manifolds to soak then took iced water that's at its coldest, maybe with a bit of salt in there for a lower temp, with that being splashed on the manifold/nuts/bolts to break them loose.
I have plans for a set of long tubes, high flow cats, and a pair to the rear out the stock pipes via local shop because I don't have the patience to do it myself. ;-)
I have a standing quote for about $3,500CA all-in which is pretty reasonable considering all of the grief I remember from my youth where buddies and their manifolds were sitting on the driveway with tears because there were broken studs still stuck in the heads. ;-)
If your exhaust shop isn't set up to do mandrel bends,you might want to buy a mandrel bent builders kit,from someplace like Magnaflow.Crush bends will kill any advantage you'd get from long tubes.
If you're in the Red Deer area Flo-Pro has one of the biggest Mandrel benders in Canada.
