The time has come, zone or bds lift 4"?
Adamcr68
Lorton VA
Hemifever 5.7
This is mine on stock tires and rims. Zone 6" with their UCA's. Front is 5", rear is 3". About 1" of rake.
Drives better then stock and looks great IMHO.
I was in the same boat you're in with lifts. I.E. brands, height, shocks, additional accessories. I have a multi page thread in here if you want to take a look at that. I don't know how to attach it though.
@Quick_Shifter did the install and answered my seemingly endless amount of questions and bought the package from @Nick@GotExhaust.
Good luck with your search.
I bet I could give you a run for your money on endless questions for Quick_Shifter & Nick, surprised they didn’t end up blocking me!
minotto
minotto
italy
Questo è il mio su pneumatici e cerchi di serie. Zona 6" con i loro UCA. La parte anteriore è 5", la parte posteriore è 3". Circa 1" di rastrello.
Marcia meglio dell'originale e ha un bell'aspetto, secondo me.
Ero nella tua stessa barca con gli ascensori. Marche IE, altezza, ammortizzatori, accessori aggiuntivi. Ho un thread di più pagine qui se vuoi dargli un'occhiata. Non so però come allegarlo.
@Quick_Shifter ha eseguito l'installazione, ha risposto alla mia quantità apparentemente infinita di domande e ha acquistato il pacchetto da @Nick@GotExhaust.
Buona fortuna con la tua ricerca.
Did you have 35s sir ?
Nick@GotExhaust
Supporting Vendor
SC
for the 2.5's you can get a set that will work in the 4" kit but you will want to keep the spacers and run the 2.5's for the "stock" height. If you go with the 6" kit you can either do the 2.5's for stock height or remove the spacers from the lift and run the 2.5's for 6" kits to have a full length coil over.
Message me and we can discuss options and pricing
minotto
minotto
italy
Hi Nick, so I should buy the 6" zond40 kit which has the 3" rear springs and replace the front strut spacers with the fox 2.5" adjusted up to 5" (the 4" "stock" height of the fox 2.5 with code 883 -06-073 + 1" of extension of the 2 total that these shocks offer) to have a perfectly leveled truck. I think my truck have 2" rack but i understood that i can set till 6" fox 2.5 ....right ?
Nick@GotExhaust
Supporting Vendor
SC
Yes that would work. To be clear the front lift will vary depending on options, accessories, etc...which all increases weight. Luckily once installed if it does not sit perfectly level you can adjust it to it the way you like.
Message me if you would like a quote
Moe70
PA
Here is my 2021 with the BDS 4” kit. Installed by AK Trucks in PA. The only guy I would trust to do something like this to my truck. The ride is awesome.
2Tallguy
San Diego
5.9 diesel
I preferred to open a new thread to get more direct advice and choose my definitive setup.
I have a 2016 Ram 1500 Laramie with 3.21 gears 5.7 hemi that currently has 20" wheels with 275/60r20 tires.
I have the 1" Eibach springs at the rear and 2.25" at the front installed on the Bilstein 5100 set to 0. Ok, it's fine but it doesn't satisfy me anymore!!
I decided to redo the look of my truck and I want to fit a kit with 3" springs at the rear and the Fox 2.5 DSCs at the front set for a total of 5" (4"+ 1")
The zone kit costs around $1670 with fox 2.0 adventures rear and 3" springs
The bds kit costs around $2600 with fox 2.0 performance rear and 3" springs
The fox 2.5 dsc with code 883-06-073 are 4" longer than the stocks and offer an additional 2" of adjustable lift by screwing or unscrewing the collar with the thread (price around $2200) therefore setting the front of the truck to 5" I should completely eliminate the rake and have a perfect level.
Can I combine these fox 2.5 with both kits which basically offer the same components?
Is Bds worth $900 more?
There is no option on zone or bds to match the adjustable fox 2.5 dsc so I will have to buy them separately.
I was also thinking about getting just the zone kit without the fox 2.0 for $1370 and investing another 1500" for the fox 2.5 dsc on the rear too.
Is worth ? For the rear, would there be much difference between the adjustable fox 2.0 and fox 2.5 dsc?
To recap the options
Option 1- 4" Zone Kit with fox 2.0 adventure at $1670 + adjustable fox 2.5 dsc $2200 = $3870
Option 2 - 4" Bds kit with fox 2.0 performance at 2600" + adjustable fox 2.5 dsc $2200 = $4800
Option 3 - Zone 4" kit without shock $1447 + fox 2.5 dsc front $2200 + fox 2.5 dsc rear $1500 = $5147
I want to run with my 33" wheels at the beginning and only after they have worn out move to 35".
Considering that I live in Italy and will have to order everything online, can you advise me if the setup I chose is valid and which brand to choose?
I'm sure I'll put the 2.5 in the front but as I don't do offroad and drive most of the time on the motorway and in the city, perhaps for the rear installing the Fox 2.0 might also be sufficient.
I await your feedback, please help me with this build.
Thanks and greetings from Italy
Carli Suspension has a thoroughly engineered system for your truck. Pricey but it's the best in the business. I don't see if your truck is 2wd or 4wd? https://www.carlisuspension.com/ram-1500/2009-17/
mrack
Carli doesn’t do lift kits like the op is wanting, they do suspension systems. And IMO Carli isn’t the best option for half tons anyways, it’s the 2500s and up where they really shine.
Yeti15
Washington
Don’t know about zone but I do know that Fox owns BDS. For the price difference your getting something similar to Fox themselves.
If you can afford Fox though I’d go that way. Have them on my 15 and it’s a game charger
Source - best friend is the engineer for Fox in charge of all OEM applications and developed the new Raptor shocks.
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
Zone and BDS are owned by Fox. Yes it’s all one company but they are not compatible. BDS comes with the performance series Fox shocks, stainless brake lines and more ground clearance. It’s beautiful to see 3-4 of the trucks I’ve personally done above but the long and short of it is. Many of the trucks I do I incorporate all the bonus options that BDS comes with. Think of it this was if BDS is in the budget that is the road to take. Zone is the budget friendly option that will leave room to upgrade over time. @Nick@GotExhaust has these packages available called the quick_shifter packages that offer everything from the one and done to the base kit and upgrade over time
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
You’re not alone……
ProsperRam
Prosper Texas
Hemi 5.7 (eTourqe)
i always considered a body lift a short cut
but who knows, the OP might find it acceptable
I had a body lift on a 2002 F150. it worked well. I got thr look i wanted and the stock ride was maintained. If you are going for looks, a body lift is a great option.
Ktaylor_j
Alberta
I’m running the Zone 4” lift with Bilstein 5100 series all the way around. I love it it so far. The only thing I need to look at, is possibly adding extended cvs to correct the choppy parking lot turning.
Had to set the front Bilsteins to 0.75 to knock the rake out.
Adamcr68
Lorton VA
Hemifever 5.7
Stance is perfect IMO. Looks great!
dk_ace
When I compared the zone and bds kits there was one notable difference that almost talked me into the bds - the bds has more ground clearance. OP isn’t off-roading so that won’t matter for him.
D
