Theme display troubles
Scott Turnage
Missouri
201@
Anytime I go to Apps. Settings. Display. Set theme, there are five choices. If I select one (let’s say blue) the color on display will remain but anytime I shut the truck off and restart, the font changes back to original (dash display mph etc). What’s the deal?
Beltsand
SD
N/A (prior 2010,2019,2022)
Cummins
Just a thought: If you have your user settings tied to FOB option turned on, it may be reloading your saved preferences each time you start your truck. Try setting the display theme where you want, save your profile with the buttons on driver's door, and then see if it remembers the change next time you start.
Scott Turnage
Scott Turnage
Missouri
201@
I tried that too. Not sure what the problem is. It’s really not a big deal. It’s more of a quest now to figure it out.
Narg
Tulsa, OK
5.7 eTorque
The manual states the thing that Beltsand said. Some have reported other issues with the memory buttons, so you might hit up your dealer service guys.
