chaosh1
So ill start by saying that i follow details/trends and i have become hypersensitive to temps/value changes so i'm probably over doing it. What makes it worse is my Edge CTS3 is "permanently" mounted so i see it all the time. ill add a picture just to see that you cant miss it even if you tried.
For the longest time my coolant temp sits at 187 and nearly never moves. Recently, i have noticed that when i start going up hills i can see coolant temp quickly rise by 10-15 degrees and are a bit slower to cool than they used to be ( It still drops back down to 187) and it never used to be this way. I saw this yesterday driving up a hill i always drive and really questioned it because the OAT was 58-64 degrees. I suspect that the Thermostat is starting to show early signs of failure. My question here is:
How hard of a job is the Thermostat change on the 6.7 and how do I bleed the air after as we don't have a Radiator cap, It may also be time to change to silicone upper and lower hoses, any recomendations?
2018 58k miles
2018 58k miles
