michaelrc51
This will be my first travel traveler, the one I am possibly buying is a 2008 MacKenzie Dune Seeker 260 FQB Toy Hauler. I have a 2009 Ram 1500 4x4, I'll get to the specs shortly. TT will come with weight distribution hitch and setup.
My truck is a 2009 Ram 1500 4x4 with 5.7l with bolt on mods: Ported TB, Air Grabber, Efan mod, 180 t-stat, MSD coils, Icon Stage IV suspension set to 3" front lift and 1.5" lift rear coil, 1.5" Zone body lift, wheels with 35" tires, Zone UCAs, Hellwig RSB, adjustable SWB links F+R, Trinity programmer, and just put an ATS Stage IV trans in with converter and Co-Pilot.
Planned mods for towing are: 4:10 Gears for F+R, Auburn LSD for rear, add an external trans cooler w/fan, brake controller, and air bags for the rear.
Trailer Specs are:
30.5" length
6100 lbs dry weight
1170 lbs tongue weight (this is a concern)
11000 lbs GVWR
My questions are:
1. What air bags should I consider?
2. Are in coil air bags good enough to handle my load?
3. Will in coil air bags fit inside Icon springs?
4. Is this tongue weight going to be an issue?
5. Any other concerns?
This will be my first trailer, just wondering what other things I should be thinking about here. TIA
Trailer Specs are:
30.5" length
6100 lbs dry weight
11000 lbs GVWR
My questions are:
