Third brake light leak question.
Limeybastard
Shady Hills, Rednecksville Boro, Florida.
I'm well aware about the cab stop light water leak and that water pools into the area behind the driver seat.
I removed mine for LED upgrades, so I wanted to specifically know if a minor leak occurs where can it be detected inside cab first. I re-sealed but didn't take off the foam seal that was already in place , washed truck and wanted to chase a leak, if present. Thanks
Sent from my SM-N910T using Tapatalk
RodRam
Ga.
if you put more weatherstrip over the factory that was in good condition, it wont leak.
smoothee
St. John's, NL
I'd just do a garden hose test or something similar for a few mins, you'll know right away if there's any water getting in still. I recently replaced the weatherstripping on mine too.
Limeybastard
Limeybastard
Yeah. It was in good condition but I tore one corner up then put it back down and added Eastwood caulk strips.
Was wondering where the trickles of water would first get to on a weak leak if one existed.
RodRam
Ga.
it depends on where the leak is, mine leaked into the far right passenger side down the seat,
BlownGP
Houston/Baton Rouge
Far right passenger back or front , with far right you mean near door edge area?
Also, does the roof line get wet or not always necessarily. Ta.
Mine leaked on the passenger side corner and yes the liner got wet, because would just come down through it on to the rear seats.
BlownGP
Houston/Baton Rouge
Passenger side roof headliner corner ?
More or less. Mine was so bad it was pretty much came down towards the center too..
Makes sense whys there's rust on some of seat brackets. Previous had no idea WTF was going on. Probably why it was traded in. lol
Ed11
