Throttle body cleaning
dakotanut
Needville, Texas
Can I use any throttle body cleaner or does it have to be something specific? Mine is filthy. Filter is filthy. Not my doing. Bought it this way. I'm pissed.
U&A
2016 3500 SRW
6.4 HEMI
Any Throttlebody cleaner and don’t use anything besides throttlebody cleaner. I like CRC. Somethings can hurt the special coatings in it or penetrate into the electronics
You taking the TB off or doing it on the truck?
I recommend taking it off.
Discount the battery either way.
Sent while firmly grasping my redline lubed RAM [emoji231]
dakotanut
dakotanut
Needville, Texas
I pulled it. And will remove it again. I ran out of throttle body cleaner.
tantore
texas
some guys on this forum use brake cleaner including myself with very good results
U&A
2016 3500 SRW
6.4 HEMI
Use what you want.
How much does a new throttlebody cost?
I’m gonna spend the 5 to 6 dollars for a can of the stuff that is made to clean it. Its silly not too.
Throttlebody cleaner it’s probably cheaper than break clean. If not its close. and much safer. I don’t see the point in taking the risk
JMO.
If you stay on top of the cleaning at the right intervals one can will last you probably three cleanings easy.
Fitz-0518
Veteran 66-68
Central California
2018 2500. 2018 1500
I will share again what I learned the hard way regarding cleaning our TB on the 5.7 Hemi. I have used CRC for years and find that it is an effective cleaner. HOWEVER, I no longer simply remove the air intake plenum and "spray" inside the TB. That will cost you a replacement TB on some 5.7's. I say some because some members have reported that some years TB have a different design than the early models. On the 03 and 07 the spray can get into the sensitive electronics of the TB module and you begin the code, run condition diagnostics issue. In this thread you will find in the archives some great tips and suggestions on how to clean the TB with out the risk of knocking down the module. BTW since I installed a catch can (UPR) I have not yet had to clean the TB and that was about a year ago.
Reactions: U&A
Doodoo972
Martinique
Ok thanks for the advise. I'll see if I could find TB cleaner for the next time.
crackerjack1957
2014 Sport 1500 CC 4x4
Hemi 5.7...65RFE...4.56
Protective coating on bore???
crackerjack1957
Think this would apply to brake cleaner also
Basic Chemical Structure
Both carb and TB cleaner contain between 20 and 30 percent acetone, which is a good all-purpose solvent for any kind of hydrocarbon. Carburetor cleaners tend to use the very aggressive but quickly evaporating toluene to melt resins, whereas TB cleaners tend to use the slower evaporating and less-aggressive xylene to break apart heavy soot particles and oil. TB cleaners generally contain higher quantities of glycol ethers, which slowly evaporate, repel water and act as a "soap" to make the metal surface slick.
Myth Busted
Contrary to common belief, carb cleaner isn't just "throttle body cleaner with some extra oil to lubricate the parts." Carb cleaners specifically are designed to aggressively dissolve a thin layer of resin then evaporate as quickly as possible. TB cleaners, on the other hand, are lingerers; they sit in place for a while, breaking heavy carbon apart and leaving a slick surface to keep carbon and oil from sticking in the future.
Applications
Yes, you can use carburetor cleaner to clean a throttle body, but not without making a few compromises. Carb cleaner doesn't penetrate and hang around to break up heavy deposits, so you'll end up having to use more of it in multiple passes to remove heavy carbon buildup. And when you're done, you've got a TB that's squeaky clean, but will quickly accumulate more carbon and soot buildup. So, while you can use carb cleaner on a throttle body, you're better off spending the same $2.95 on TB cleaner specifically engineered for the task.
https://itstillruns.com/can-use-carburetor-cleaner-throttle-body-fuel-injected-car-12213280.html
