Tire pressure gauge suggestions?
Truck Fun
Missouri
2021 Classic
Looking for suggestions on who currently makes good tire pressure gauges. I prefer a dial with a hose. Will need at least 80 lbs so I'm looking at options with a 0-100 range. Might also consider getting an inflater style for some uses but I've never had/used one of those. Thanks.
kad
Hudson Valley, NY
5.7L HEMI
I use one of these in the shop:
And keep one of these in the truck:
-K
Digital gauges are great tools, until someone puts them in a tool box & tosses a Ratchet wrench on top of it
A shop that has a Shop box, where more than one person works out of the box, is taking chances. i have seen it happen more than once with a Digital Torque Wrench :(
I can be a bit rough on my truckers tire gauge, as long as the gauge is pushed in
PaleFlyer
Charlotte NC
Just slide it into a piece of PVC pipe, with end caps!
Zoe Saldana
california
6.4l
-K
Those are great. Very accurate.
Badger 13
North Idaho
2013 Dodge Ram 1500
I have used different pressure gauges since the 60's when my Dad had a service station. Milton was the big name then, and they do make nice products. I have also used Snap-on analog with the hose. A couple of years ago I purchased a Longacre brand, and I have found that to be the best tire gauge I have ever used. Analog with hose and a 2 1/2 dial. They are on the pricey side when it comes to tire pressure gauges, but I feel it is well worth every penny.
Tire Pressure Gauges - Longacre Racing
https://www.longacreracing.com › products
longacre tire pressure gauge from www.longacreracing.com
Whatever your preference for an air gauge, Longacre has you covered. Digital, analog, liquid filled or filler gauges and air tanks. Quality air pressure gauges
T
Truck Fun
Missouri
2021 Classic
Ended up getting some Longacre gauges. Have been please with them.
