hrazz7
Got a 2013 Ram, looking to run 33 by 12.5 on a 20x12 rim with a 2.5 inch level. Just wondering if anyone has the same setup and what kind of tires they are running? Leaning towards trail grapplers.
Just FYI, you can go to 35's with that setup too.
Just be mindful of the wheel offset. With a stock offset you may run inside at full steering lock. A -12 or more offset on your aftermarket wheels will make sure rubbing won't be a problem.
About the tires...will you be off-road much? Need to move through some mud? Or will you be mostly on the highway?
Aggressively treaded M/T tires work well in mud, sand, etc... but will normally wear faster than an A/T on the highway. They can also be a bit noisy.
A/T tires work well on the road and in wet conditions. They aren't bad off road but suck in mud and sand. They are pretty quiet on the road and wear really well.
I've had A/T and M/T. Recently I installed a set of BFG All Terrain KO2's and I really like them. They aren't as noisy as the Toyo, Super Swamper, Mickey Thompson and the more aggressively treaded Goodyears, Nittos and Cooper M/Ts.
Picking a tire can be for looks, function or mileage. Good luck with your choice.
You or only don't want a 12 wide rim for 12.50 wide tires.... Drop it down to 10 wide rim...
Yall ever look at custom offsets website? I was looking at some of the trucks and specs on them, it seems like a 20x12 with -44 offset runs with no rubbing with a 33x12.5. Did see a few with the same combo but with 35x12.5 with slight rubbing. If any of y'all are running aftermarket rims, what are y'all running?
