Tires , cant decide between two
fadetoblack188
Ok guys I am torn between these two tires cant decide what to pull the trigger on.
I do some beach driving, trail driving when I go hunting and it snows a good amount here in ny.
Help me decide!
275/60/20 - nitto terra grapplers g2s
275/65/20 - duratracs with e rating
coldfusion73
Ontario, Canada
I had the Duratracs on my last truck. Best tire I've ever owned. I'm in northern Ontario and get tons of snow. I put 60,000 km on them before trading truck in and still had lots of tread left. As soon as my new factory tires wear I will be getting the Duratracs again. I have no experience with the nittos so can't give an opinion on those.
chris52010trx4
ontario
Good to know from Northern ontario too and just put a set of 285 70 17 duratracs... seem pretty good on wet and dry so far ... hasn't snowed much yet though
Sent from my SM-N910W8 using Tapatalk
Lufty
Banned
Wi
2021 REBEL
I did the g2s in the stock size(275/60R20xl). On road they are a comfortable ride and quiet. Wet traction is better than stock Goodyears. Haven't been off road yet but I'm sure other will chime in.
huntergreen
Marine Corps Navy Badge
any roadnoise with those? tks
gigabyte3
I have the Nitto G2 tires in 275/65/20, have had them for about 2 years, love them. Not really any road noise. I used to have the first gen Terra Grapplers on my 2004 ram. Got 60,000 per set on that truck went through 3 sets before i sold it. Wont put anything else on my truck. Keep in mind, make sure your front end is 100%, or you'll chew up any tire faster. I believe nitto also has a tread life Warranty on their tires. To my knowledge duratracks dont. Someone may correct me on that though.
develand
If nitto is an option, I would suggest swapping that choice out for Toyo AT2 tires basically the same tread but with a higher mileage rating and better road hazard type warranty.
I ran the Toyo on my last truck and they were awesome all around. New truck has BFG KO2 though.
RAM_Designs
Rockwall, TX
6.4L Hemi
I like my 37" G2's so far, dad got the same in 295/70/18. The Duratracs are MUCH more expensive than the G2's.
F
fadetoblack188
250 was the price difference out the door between the duratracs and g2s here
