Tires wheels and tpms
derag2
6.4 hemi
I'm looking into getting rims and tires from mr wheel deal. In thinking fuel boost fuel vapor or possibly xd monster.... Leaning more towards fuel boost... Truck is a 14 2500 maximum steel metallic. They can put in tpms sensors from orotek, but According to website they arnt compatible with oem system but mr wheel deal says they will work. Anyone confirm this? Sticking with stock tire size possible move to 35x12.50 later.. Will 18x9 8x6.5 pattern -12mm offset work. I don't want them to stick out much more than stock but still want the option of 12.50 later....
What do you guys think or any other rims I should be looking at that I'm not yet?
Thanks
AustinB
Banned
San Diego, Left Coast
I have no idea. Nice wheels though, I was on a tossup between those and the fuel revolvers.
jstacey8
hiram maine
The sensors I got from mr wheel deal don't read in my 14 1500. And if your frugle like me get a quote from rimzone and mr wheel deal and make them have a battle for the lower price and you'll save some $$$
Jerry1984
Meridian, Idaho
My sensors from mr wheel deal worked no problem at all. 2014 1500.
Drummin4jc
WWG1WGA!
SW Pennsylvania
2024 Ram 2500 CC
rimzone best customer service and prices I could ever find
I'm the opposite. I priced everything up from Rimzone and Mrwheeldeal and Mrwheeldeal DESTROYED Rimzone's pricing. To the point where I can get 37x13.50 widths for LESS than the 37x12.50 from Rimzone. That's just my experience so I will be ordering from MrWheelDeal next month.
Adam
Thatdude596
buckeyes state
2009 ram big horn
Adam
toyos?
D
derag2
6.4 hemi
My quotes from mr wheel deal is also cheaper than rimzone... Rims and tires both cheaper.... I'm just trying to figure out what offset I need... -12mm is going to stick out farther than stock I think...?
brandonjansen
Abbotsford, BC, Canada
2012 Ram 3500 Laramie Limited
Mr. Wheel Deal is generally cheaper for both wheels and tires. But it does depend on the exact package that you're looking at. All depends on the relationship they have with the suppliers.
An 18x9 -12 offset is going to stick out way further than your OEM wheels. About 2" further with stock tires. With 12.5 wides it will be half the difference between 12.5 and your stock tire width more. If you want them sitting more tucked under the truck I'd be looking at a +12 offset at a minimum. A +18 offset may be a better option if you want to keep them tucked under the truck as much as possible.
MADDOG
Living in a Firepit
6.4L HEMI
Why not swap out the stock TPMS to the new wheels?
D
derag2
6.4 hemi
Saves from having the broke down to replace them.... I'll Or only end up using mine out my stockers.
D
derag2
6.4 hemi
I can get fuel boost in a -18,+1mm or +20mm. So a +20 would be closest to stock. Would I still be able to run a 12.50 with a +20 in a 35?
Drummin4jc
WWG1WGA!
SW Pennsylvania
2024 Ram 2500 CC
I'd go with the +1's.... +20 would probably take your wheel/tire in too far.
Adam
D
derag2
6.4 hemi
Mr wheel deal recommends the +20 they says the factory offset is +40.
