Then my friend you should prove us all wrong and do without a catch can and keep your Hemi to 200K miles--
if you can.
I have collected more than 20 oz of funky milkshake over the 14K miles I have had a can installed.
As an old Navy wrench, I have seen intake valve fowling from deposits in normal fuel, both gas and diesel. Petroleum products transform in the presence of heat, with less flammable components thickening and adhering to metal surfaces only to bake in place. It's not cook-off hot in the intake manifold, afterall its plastic. So allowing vaporized motor oil mixed with water vapor and piston ring blow-by products derdged up form the engine sump through the PCV to enter my air intake passages--without the benefit of fuel to help burn it off since of course these engines are fuel injected--is just bad mechanical practice.. The lack of a can or other disposal method is due to laziness on the part of auto manufactures, because they know it wont be a problem until after you trade it in, or the term of the five warranty. It's just like the **** who leases a vehicle for 36months and never changes the oil--its someone else's problem. Or Ford deciding not to deal with the Pinto gas tank problem, except a catch can is DIY and a good investment.
