Too much junk hanging below the rear axle!
Jebb
I have a 1500 4x4 with 35" tires - and it appears I have LESS ground clearance than a Toyota Tacoma with 29" tires.
Why is there so much "junk" (shock brackets, sway bar, brake lines, etc.) hanging below the rear axle?
Have most of you guys moved this hardware up out of the way? If so, how?
S0CAL
US Marine Veteran
The Lonestar State
2021 Limited Longhorn CTD HO DRW 4x4
Cummins 6.7L HO
Funny, I was thinking the same thing as I was visualizing the Zone lift I am getting soon. Not the cleanest footprint underneath.
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
There looks to be nothing hanging down below the pumpkin.
Welcome to modern pick ups. Go getcha old military axles and swap them out, or live with it. They have entire businesses depending on your local that just sell old military axles. They last forever and a day. These trucks are built with gas mileage in mind, if you really want capable, you should have bought something else.
Jebb
Jebb
Your photo shows exactly what I'm talking about! Look how much clearance is lost under the AXLE (not the pumpkin) because of the sway bar and shock mounts. All of that hardware could have been moved up parallel to the axle axis - gaining about 3" of ground clearance (equivalent to 6" bigger tire).
Yeah, I know, it's a pickup truck not a Humvee. Still...
Jebb
Jebb
You mean like a Tacoma? :crazy:
My point is if you're going to build a 4x4 why ruin it with all this ill-placed hardware?
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
Yes but nothing is below the pumpkin , no sway bar would be better but the shock mounts are close to the tires so I would not think you would really hit them on much.
14RAM4X4
Sweating somewhere in South Texas
2015 RAM 2500 4x4
6.4L Hemi
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
Not being a smartass here, Are you really going to take a brand new truck hard core offroading that its going to make a difference if that sway bar is hanging down ?
If so I would think you should have bought a 2500 so you had a truck with a straight axle so that it can flex and have a good working front suspension rather than this IFS thats meant for pavement before offroading.
Jebb
Jebb
...you should have bought a 2500 so you had a truck with a straight axle so that it can flex and have a good working front suspension rather than this IFS thats meant for pavement before offroading.
I don't need the load capacity, weight or cost of a 2500 - and you're missing my point. Pickup trucks (including 1500's) are TRUCKS, not cars. They are intended to haul loads down muddy farm roads, through snow, etc. It would make sense to design it to make the most of what it is - even if it's a 2WD truck. Mounting all this hardware below the axle is counterproductive.
So, to gain 2" of ground clearance you could spend $10k on a lift kit and 37" tires - or you could cut the shock brackets off and move them up 2" like it SHOULD have been from the factory, i.e., clean.
That's what I plan to do anyway. Yes, on my brand new 2017. Just curious here if anyone has done this already.
MODERATOR - this is a ground clearance topic which is why I posted it in the "Lifted" forum.
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
I am not missing any point, what you described your truck being able to do it already can in stock forum..lol
Move the sway bar and shocks up and the pumpkin is still going to hang you up just the same.
I can understand the sway bar but the shocks are so close to the tires I dont see them cause problems except once in a blue moon.
Just seems like alot of work to go down a muddy road..lol j/k
Well when you get done post up some pix. :)
JPT
NY
2015 Big Horn
I had 35” tires on my 2002 wrangler. I had to move my shock mounts (were in the same location close to the tires) after I kept ripping them off.
It is very simple to aim larger rocks on either side of the pumpkin, but if you have sway bar/shocks mounted on either side, you have no option of getting past the obstacle.
If I had the money to take my truck on trails, I would be in the same situation as the OP. It always is weird to me to see vehicles targeted for off road (see almost every SUV/Truck commercial) while they have things like these hanging so low.
Jeepwalker
WI
2012 Reg Cab, 4x4
That's one thing Toyota does a masterful job at. Their pumpkin is also pretty high up there.
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
Well its not needed if you not going to take it offroad and just down muddy ,rough, snowy roads (see commercials you speak of for Ram trucks)
Like you said rock crawling or severe trails sure, but the 1500 with its IFS is not the best choice of truck for that to start with and why they make the Power Wagon.
Riccochet
Somewhere around Charlotte
2020 2500 Laramie Longhorn
No truck is really meant for that with it's long wheel base. I always chuckle when I see these trucks out on the trails and they get high centered on rocks or mangle their rockers. Meanwhile my Rubicon with a measly 2.5" lift and 35's walks over everything in it's path.
As for stuff hanging down, even my Rubi has shock mounts that hang down. I've welded skid plates to them though, trunioned the axles, skids on the diffs and everything important underneath. I still bang off rocks and slide over stuff. I just couldn't imagine having an extra 6 feet of wheel base to worry about.
Lifted trucks are cool, I just don't think they are meant for anything more than mud, gravel, snow and relatively easy off road obstacles.
Phil21502
Frostburg, MD
I took the rear sway bar off my 15 ram 2500 for this very reason. Really helped the look from the back of the truck and zero change in handling. Heck might even ride smother over speed bumps. Lol
