Hookedup87
Mobil 89 mid grade
only use shell 91 oct and a turner runs great !
For what it's worth from the AAA . And yes I switched to Top Tier.
https://newsroom.aaa.com/2016/07/aaa-not-gasoline-created-equal/
Among brands tested, non-TOP TIER gasolines caused 19 times more engine deposits than TOP TIER brands after just 4,000 miles of simulated driving. Such carbon deposits are known to reduce fuel economy, increase emissions and negatively impact vehicle performance, particularly on newer vehicles. To protect vehicle investments, AAA urges drivers to use a gasoline that meets TOP TIER standards for engine cleanliness and performance.
The Redline SI-1 more than makes up for the cheap gas IMHO.I run top tier only and use Red Line Fuel System cleaner 2x a year.
I normally use Shell. When I was going through the process of getting a custom tune the tuner looked at the data I sent him from my truck. He said whatever gas I was using was pretty bad. I was using Costco. After that I ran the gas tank almost empty and refilled with shell. The next time I sent him the data he could tell I switched brands and said the fuel looked good. He recommends using shell or BP for gas. I knew someone who has a hellcat and he normally used chevron gas in it. After telling him what the tuner told me about the fuel. Next time he filled it up he tried shell and said he could tell the difference between shell and chevron gas in his hellcat.
I know the voices in my head aren’t real, but man, do they ever come up with some great ideas.
Too bad the article doesn’t list which brands that did better and the ones that didn’t.
Ya do not really need 89, in fact you will get less mileage with 89 than you would with 87.l And unless you are some kind of racers, heavy load puller/hauler, etc you will never actually tell the difference between the two grades. good luck.There is nothing wrong with Cosco gas....in many cases...the truck delivering to Cosco drives down the street and delivers to other name brand stations as well. Been using Cosco fuel for years....still do in wife's SUV but since buying my Ram I use Fred Myers because Cosco doesn't sell 89.
https://customerservice.costco.com/app/answers/detail/a_id/9230/~/costco-gas-station-faqs
