Tow/haul mode MDS
Bullitt279
South Carolina
Can running in tow haul mode hurt our trucks in long run if not actually towing or hauling? It gets rid of the annoying drone IMO running Cherry Bomb Extreme. Thanks for help answering
NewBlackDak
6.7L Cummins
Keep in mind that tow/haul will lock out your top gear. Manually shifting to the highest gear will turn off MDS, and not alter your normal shift points.
bassheadhemi
Montreal, Canada
With the 8-speed in tow mode it will use the 8th gear and will not get rid of MDS. Only manual shift does
JoeCo
NY
I've had the cherry bomb extreme for a year or two now and this is pretty much what Ive always done other than on longer highway trips.
clh1220
st Louis
It does not Lock out 8th gear. Shift it to 8th if you want the mds off.
