tow hooks ordered
iam_canadian22
northern ontario
ordered a set of tow hooks today for my 13 sport, 168 for the pair from dealer, was kind of surprised, couldn't even find them that cheap online, they warned me that they sit low in the opening on the sports but I already knew that from here, ill post pics when I get them on
Arctic-Rodz
RGV, TX
6.7L Cummins
awesome, would like to see pics of it when youre done. i want to add them to mine too
outlaw52
new york/pennsylvania
they fit fine. easy install. hardest part is cutting the opening I did it with a small dremel came out perfect.
iam_canadian22
iam_canadian22
northern ontario
my opening is already cut, I have a 20" led light bar down there only piece of the plastic left it where the tow hooks go so I just have to remove those leftover pieces
PRammer
AB, canada
Excited to see how it turns out, i just ordered an aries bullbar today and light bar in the future because i was told they wouldnt fit with the new fascia... :(
iam_canadian22
iam_canadian22
northern ontario
the westing offroad light bar fits, its listed as doesn't fit because it requires trimming or removal of the plastic insert, its on my to get list also in order to raise my led light bar a bit higher
apepe0738
Peoria, Arizona
2012 Ram 2500 Crew Cab 4x4
Don't mean to burst your bubble:
2009 to 2013 Dodge RAM 1500 Front Tow Hooks Hook Black Mopar Factory | eBay
Steve White Motors
If you can take a picture, I have an Express I want to do this to...
iam_canadian22
iam_canadian22
northern ontario
iam_canadian22
iam_canadian22
northern ontario
well got them on on this chilly morning, install took all of half an hour, trimmed what I had left of the bumper insert with a dremel, here's a couple quick picks
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
iam_canadian22
iam_canadian22
northern ontario
you can remove the entire piece, its just held in by locking tabs from the back, im not sure if you can buy the premolded pieces with the holes already in them to fit the sport or not but I will look into it as I plan to put a westin light bar to raise my led light bar a bit higher
Baja4701
My Sport is a 2014 and has a splash type guard under the chassis right behind the front end clip and bumper.
Does that need to be removed in order to bolt the hooks on?
JohnD72
Charleston, SC
iam_canadian22
iam_canadian22
northern ontario
It does not, the only thing that has to be cut or removed is the insert in the lower grill
