Tow Mirror Wiring Harness
haleme
VA
Does anyone know if the tow mirrors' wiring harness can be purchased/obtained without the entire mirror assembly?
The wiring for the turn signal/defroster on the passenger side has been pinched and cut due to the spotter mirror holder binding on the wiring.
Gordo2212
Mississippi
2018 3500 Tradesman
6.4 L Hemi
Could try posting in Benny’s MOPAR parts section? I think he would know if there is a stock OEM wire harness that you would be able to change out.
haleme
haleme
VA
DC Tradesman
Washington
If it was the door wiring harness I’m sure you could.Find the harness P/N on the harness. Go to the Mopar site & look it up. Personally I would just cut out the bad wire section, strip,splice, solder and heat shrink than test for open.
jr27236
New York
Take off the glass and repair the wires. Use shrink wrap on all connection and it will be fine.
CanRebel
Toronto
I would do like DC Tradesman said above.
If it's just wire cut. Simple and fast. If you don't have soldier gun or like to do it.
You can purchase wire crimp connectors or heat shrink butt connectors. Put some electrical tape.
$20-$30 from Amazon, finished in few minutes.
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
It does come apart & go back together fairly simply
Someone had to assembly the mirrors, there is nothing magic about them
GTyankee
3.0 ecodiesel
You see the wire ends in the images above, they plug into the mirror motor & turn signal/courtesy light
The other end of the wires is in the door, they plug into this type module
haleme
haleme
VA
Thanks, I'll just soldier them.
I'll have the mirrors off the truck and was hoping there was an inexpensive harness I could just snake through and be done with it.
