You need to know some data about your truck and then use that data to see what it will actually handle safely.
Data about the truck:
1. Curb weight - empty truck, no fuel, passengers, etc...
2. Loaded weight - Truck with fuel, passengers, gear, truck boxes, tools, hitches, etc...
3. Gross Vehicle Weight Rating - The truck's loaded maximum weight. This is the loaded weight plus the tongue weight (TT) or pin weight (fifth wheel) of your trailer. (GVWR)
4. Gross Combined Vehicle Weight Rating (GCVWR)
The curb weight, GVWR and GCVWR numbers are available in the Ram Builder Guide.
Data on the trailer:
1. Trailer Unloaded Vehicle Weight (UVW)
2. Trailer Gross Vehicle Weight Rating (GVWR)
-- The difference in 1 & 2 should be the cargo capacity of the trailer --
3. Tongue weight or pin weight of the trailer
Now you are going to use those numbers to calculate the load your truck will experience and whether you are over or under the GCVWR.
There are some good calculators online to use. Just plug in your numbers and see what it says.
Or, PM me here with your email address and I'll send you a spreadsheet you can use.
