TPMS pressure change
cowbell
Have 2015 Power Wagon. purchased used with larger, 325/18 tires. To get a comfortable ride and even tire wear pressure needs to be around 50 to 55 lbs. but this causes TPMS light and center cluster to come on. Dealer says they are unable to adjust pressure parameters anymore because of "liability" issues. Anyone find a way to overcome this?
MADDOG
Living in a Firepit
6.4L HEMI
I believe there is a thread in the HD section that speaks to this.
On a 14 truck the tech can touch the proper modules with a scan tool. However, if they've updated their tools, that function may not be available any longer.
And with 15 and up trucks, it's not possible with the dealer's tool.
There is a thread on another tool in the HD section that speaks to an aftermarket tool. Hopefully you can find someone with it in your area.
