Eagle2006
- Mar 11, 2020
- 51
- 13
- Location
- Edmonton
- 2019 Ram 1500 Tradesman
- Hemi 5.4
Hey,
So I’m sitting at the dealership for my oil change and I spoke to the shop manager about my traction control. So this has happened to me twice since I’ve had the truck once last year and once this year. It’s a 2019 Dodge Ram 1500 with the tow package and 4x4. What happens is that I was backing out of my spot on the acreage that was very icy (both instances have been on ice) so obviously slow rate of speed in reverse. Tires are just spinning on the ice and I’m not going anywhere in 2 wheel drive. So I put my foot on the brake but here’s the thing. There’s no forward or backward motion. I’m already stopped. My foot is on the brake. But the tires won’t stop spinning. I believe the traction control is designed so that my tires don’t lock up, right? But, I need 4 when drive to continue. But the tires won’t stop! The traction control is showing on the dash. But I don’t know what to do at this point. Obviously I don’t want to put the truck into park. But even with my foot on the brake I can’t get the tires to stop spinning. I also don’t think it would be a good idea to just throw it into four wheel drive at that point either. The shop
Manager says that pushing the traction control off button wouldn’t do anything either but what I did was I turned the truck off. Which was probably just as bad an idea? I don’t really know. It gave me warning on the dash when I shut the truck off about too high a speed or whatnot. Can someone tell me what I should and should not do in this situation should it happen again? They don’t know at the dealership. Is this a malfunction? Or is the traction control doing what it’s supposed to do in that situation and I can do something to stop the tires spinning? Thanks
