Traction control
Stew4169
So I understand how to turn off traction control. It does not turn off 100%. I want to turn it all the way off so I can let loose and have fun. Any tips???
whetrick1
I think it automatically turns back on when you start your truck. I think the only way you can turn it off completely is with a tuner
John Jensen
San Diego County
Ecodiesel
The F26 fuse is the only one to use for disabling ABS & ESC.
Here's my findings and suggestions.
F26 (30 amp - Antilock Brakes - Stability Control Module - Valves) is the fuse to pull.
Wire in a 30amp fuse from F26 socket to a NC (normally closed) 30amp relay.
Wire in a dash on/off switch to control the relay. *
You know when it is off because the EVIC dislpays "Service ESC" and "Service ABS" (no engine MIL light like F76 fuse)
* I used a remote controlled wireless switch to controll the relay and link it to a HomeLink (garage door) button.
This saves the trouble of pulling wires into the cab and installing a switch.
F76 fuse (10 amp - Antilock Brakes - Electronic Stability Control) - DO NOT PULL!
DO NOT USE - EVIC displays "Service ESC" and yellow engine (MIL) light (no "Service ABS" like F26 fuse).
Here's the remote wireless switch I used:
https://www.amazon.com/gp/product/B0068D0OBI/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1&tag=vs-auto-convert-amazon-20
vwboomer
I was sorely disappointed when we got our first snow yesterday and traction control can't truly be shut off with the button.
The Fun Police have hosed us in yet another way :flipthebird:
MADDOG
Living in a Firepit
Google this:
NOESP
