TheEnder
- Aug 12, 2017
- 2,093
- 1,651
- 2013
- 4.7L V8
So basically any oil filter?
Yes. Any oil filter will work for the 65.
Sent from iPhone 10S Max
I bought a heavy duty rebuilt valve body for the 65RFE in my 12' this summer when I put a high lift camshaft in the engine and deleted the mds. The valve body I bought has all the fixes and upgrades for known issues, like overdrive clutch failure, piston scuffing, and cross leaks. It was pretty expensive. Even after the seller accepted an offer but, after adding engine power, the trans became the weak link . comparing the valve body I removed to the central valve bodies one I put in it put my wallet at ease because the differences are obvious. Its built to be tuned with high line pressure and my truck makes solid shifts now. It launches from 1st to 2nd and 2nd to 3rd when flooring it.
What filter do you use when you put that metal filter adapter on?
You can use any filter. They all have a spin on top.
