Notsobroke
- Joined
- Nov 20, 2012
- Posts
- 70
- Reaction score
- 6
- Ram Year
- 2002
- Engine
- 4.7
So let me give you some history. My 2002 ram1500 4.7 45rfe trans has 70k on it. A few weeks ago the truck would shudder when in overdrive pretty much the converter locking and unlocking. No biggie I can live with for awhile. Then some time later the 2-3 shift starts slipping at low speeds. I do some research ( this forum) and figure this has to be the solenoid pack. So I gear up to swap out the pack as well as the governor and filter kit, new pan with drain plug installed.
Everything goes of without a hitch put it back together test drive goes ok. Driving home trans flairs up inbetween shifts, delayed gear selection. I had disconnected the battery while doing the service thinking that would work for the relearn. Finally get home, wifey need to go to the store jumps in it and comes back saying truck is acting up. I jump in it boom! Limp mode. Next day I go out decide I'm taking the programmer off and the line pressure booster off. I also disconnect the battery and go old school take both terminal ends off, turn ignition on and touch the 2 together to ensure complete system drain.
All this done I've been driving the truck all over and besides a few first hiccups with ruff shifts. It is working better then ever shifts are firm and positive. Knock on wood it keeps it up. And thanks to those on the site
