973604x4
Did you have any issues with slipping in 1st or reverse in the early days after you purchased the truck?
Did the service manager say the seal on the L/R Piston was rolled over and allowing fluid to bypass the lip of the seal?
Or did he just say it was installed wrong when it was built?
i had not noticed any slipping issues in the early days of owning the truck. The service manager and mechanic actually showed me the L/R piston seal. It was clear that the lip wasn’t seated correctly. They explained that the fluid bypassed the seal and, overtime, caused several transmission parts to fail. They even specified this had been an issue in the earlier days of the 68rfe but they hadn’t seen one on anything as new as a 2018.
