Transmission stuck in 1st gear
VAram71
Virginia
2018 2500 with 6.4 66rfe 93,000k
Was driving from red light and when the truck went to grab 3rd gear, revs went up like it was put into neutral . Pulled over and truck went into 1st gear. Pulled out and would not shift out of 1st. Limped back to the house about 7 miles in 1st. Got to the driveway and put in reverse and it went into reverse a little harsh. Put into drive and would only go into 1st with a little throttle. About 1100 rpms. Shut truck off . Went out this morning put truck in reverse went in like normal put it in drive and took a couple of seconds later than usual and went into 1st. Heard slight ticking before it went into gear. Drove down the road shifted into 2nd then 3rd like normal drove that way for about a mile and a half.( Dirt road) Got on to paved road and came to stop. Started out in 1st into 2nd and before it could shift started slipping and it dropped back into 1st. Turned around and it shifted like normal back home. Was very easy on the throttle. Four days prior to this happening I replaced the plugs and coil packs with ruthenium NGK plugs and NGK coil packs. (Bosh iridium was from the factory)Truck ran fine for four days then tranny problems. Was going to do fluid/filter change a couple of days ago but got up in something else. Talked to a buddy of mine that is pretty familiar with these new Rams and he said to put the old coil packs back in before doing anything else. (The resistance from the new coil packs and plugs might be messing with the computers jiving) I'm old skool but I guess anything is possible with these damn computer controlled things. I was going to start with the fluid change and if that didn't fix it was going to go with pressure sensor transducer and speed sensors. Any tranny gurus on here have any thoughts?
mtofell
Yeah, extremely unlikely the coil packs and plugs have anything to do with it. My 66rfe failed twice before 100K miles and as these age there really are a lot of reports failures popping up here. The most common problem is the valve body but I believe that can lead to other issues. The slipping is definitely a concern. Have you looked at the fluid? Burned and black or still purple? All the weird shifting stuff is textbook valve body. As for codes, definitely check but for whatever reason the tranny failures don't trigger many. My first failure occurred with me sitting on the freeway basically just in traffic. Hit the gas to go and the tach just revved and the truck barely moved. I limped it to an exit with the tranny banging and slipping the whole way. I found a parking to to pull into but had lost all forward gears. Threw it into reverse and got off the road. Almost in comical fashion once I came to rest in a spot I got a CEL. Great... thanks. Yeah, I already had an idea there was an issue... LOL.
RamDiver
Marlborough, Ontario Canada
2021 DS
My only comment at this stage is why would you drive it period until further investigation?
If a transmission is compromised, park it and start troubleshooting or have it towed to a competent transmission shop.
V
VAram71
Virginia
Fluid level was fine. Not burnt and still looks fresh even though it's never been changed . I was going to change it a couple of days prior but got caught up in something else. It's kinda weird that wouldn't even try to come out of first gear. I did get one code when I got close to home. P0 731 ( First gear ratio) . I think was do to me feathering the throttle trying to see if it would go in second. It slipped only once going from 2nd to 3rd and it went straight to first once it started slipping which it kinda does sound like something with the computers or like you mentioned maybe the valve body. Well tomorrow afternoon I'm going to mess with it and let y'all know something.
mtofell
The fluid not being burnt is encouraging. A valve body is a pretty straightforward swap with the tranny still on the truck. The rest of it gets pretty labor-intensive.
WWlorodd1
Fort Worth, TX
2011 Ram Sport
Same issue here but mine will drive fine if i use the manual shift option. I have replaced both the speed sensors and the only thing left to try is the shift solenoid inside the valve body. P0731 is the code I have. Any thought?
Muddbugge
I have the exact same issue did you get yours repaired what was the repair?
WWlorodd1
Fort Worth, TX
2011 Ram Sport
Not yet....just swapped the shift solenoid and same problem still. Next stop the shop...
WWlorodd1
Fort Worth, TX
2011 Ram Sport
Ok everyone. Been sitting on this one a while as I had back surgery and couldn't afford to get much done. Just got her back from the "Stealership" today and the diagnosis is ..... the transmission overunning clutch is shot. As this was their diagnosis they want 12k to put a new tansmission in. WTF? Can this be fixed with a trans rebuild and or is it worth the risk of a used transmission?
mtofell
First off, that's crazy money for a tranny so even going full retail at a dealer should be much less... just at a different dealer. There are some companies/manufacturers I see talked about here and I'm sure others will chime in with their name(s). I have no idea what a "overrunning clutch" is but I'm not much of a tranny mechanic and don't know a lot... other than what the dealers told me at my two rebuilds. I'd dig into that a bit to learn just what needs to be replaced and if it means a full replacement. I'm pretty skeptical of any dealer quoting 12K for a tranny replacement.... shop around for opinions/info/prices (as you are here :) )
Hagar1
Ontario Canada
2012 Ram 1500
An "over running clutch" is a holding device that is used to prevent "opposite direction" rotation in a planetary gear set. There are essentially 2 designs, over running clutch and a sprag clutch. They do the same job but now-a-days the ORC is more popular. A simple planetary gear set consists of an input member, a held member and an out put member. An automatic transmission is certainly more complex than just a simple gear set.
I'd sure like to dive into a 6 or an 8 speed just to see how they are laid out.
2003F350
6.7 CTD
As the others have said, it shouldn't run $12k for a replacement, even at the dealer - they're WAY overpriced.
I'd take the diagnosis from them (because there's a good chance it's accurate) and take it to a relatively well-known local transmission shop to see what their pricing is. I say a transmission shop because while any old mechanic can R&R a transmission, a transmission shop might actually be able to rebuild it for less, and since they're just after the parts (clutches, bearings, maybe gearsets, not an entire assembly) they might be able to get it done faster too. There is one about an hour and a half from me that I used to use when I'd have transmission issues...I just haven't had a vehicle that has had transmission issues in a while. They built their name by rebuilding race transmissions for the track they're right next to.
Whatever you do, I would avoid anything with Jasper on it - I have had nothing but BAD experiences with Jasper products, and at this point I wouldn't put one on a lawnmower. For me, it's a rebuild at the shop or OEM anymore. MAYBE something from US Engine Production but that's about it.
Hagar1
Ontario Canada
2012 Ram 1500
I really enjoyed working on automatic transmissions, I'd prefer them to working on a standard. Now, age has sidelined me to tapping out the odd message on a keyboard.
Kind of like the old dog who can only sit on the front porch and bark!
