Roaster
then you need to a little higher.
If I go any higher, there won't be any of the white plastic piece left
I'm just curious here. My Owners manual shows the "Fold Down back seat" as an option, showing release latches for the catches on the back wall. Are these Latches available, and can they be swapped out? Would that be a viable option to raising and shaving?
Interesting.
Can you tell from the manual, are they just putting the mega cab style seats in the other cabs? Or are they using a different catch on the standard seats?
The mega cabs have had fold down seats for quite a while (maybe always), but because they can recline, they have a different design than the quad and crew cab seats.
Interesting.
I wonder if you could slide the rear bench forward just a bit and get that "reclining" feel to the back as well...
Sent from my SM-N950U using Tapatalk
I am having the same issue on my 2018 except I haven't tried raising the seat yet. I cut the clips in the back probably about a quarter inch into the white plastic and the seat still won't come forward without loosening the seat bolts and raising it up a bit.
The clips on the back of the seats DO NOT HAVE TO BE CUT!
I put approx (7) 1/2" flat washers or 3/4" of spacers under mine and could've done a full 1" it bolted directly back in.
Can't tell its been modded at all. I used some hippie chrome(duct tape) to hold the stack in place.
The 18 is a full metal piece.
I Love my 18 Ram 2500 4x4 CC U.S.M.C.(ret) CPL
While you don't have to cut the clips, I don't want to raise my seat since I have a sunroof...I'd like my passengers to have all the headroom they can get! Plus, I keep bumping my little girl's head when I throw, I mean, gently place her into the car seat. I'm planning to cut the clips, myself; now that's a mod you truly can't see.
TXCOMT
