Triple bully dog gt diesel 40420
rafaelg2000
Brasil
Cummins 6.7
Hello, please can someone help me ... the last time I came to the USA brought bully triple dog gt diesel 40420, I wonder if could damage my engine, since it here in my country does not have many parts for the motor. Thank you and sorry for my english.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Welcome, the canned tunes are on the very safe side of things. Just make sure when you upload the tunes you fallow the directions.
R
rafaelg2000
Brasil
Cummins 6.7
Thanks, I already installed and am noticing that the temperature is reaching 100 º C, is it normal? Thank you.
NWRQC
Is that under normal driving or when running it hard?
R
rafaelg2000
Brasil
Cummins 6.7
Only when put in extreme, and running strong, when I walk normally it is 92 º C, can it harm my engine for the temperature to reach 100 ° C even for a short time? Thanks.
NWRQC
You're fine, but I would invest in an EGT gauge if you want to continue running hard on the higher tunes.
NWRQC
Towing up a grade I've sustained 100+ degree's Celsius (210-215 degree Fahrenheit) for several minutes, which is normal. I have my truck set to defuel at 220 degree's (or about 105c).
The engine temp will climb quickly when running hard because your EGT's are going from 700-800 degree F to 1200-1400 degrees ( or roughly 400c - 700c) and that heat has to go somewhere.
