Trouble shooting ideas for why my subs don't work
olbaid_83
Fort Worth, Texas
ok heres your problem.....if your amp is turning on fine you do not have a ground issue. if you tested different known working rca cables and still had the same issue its not that either. chances are that while installing the amp someone shorted the channels on the amp. with the amp on and the radio going, take one sub and wire it up bridged. if you get sound you got lucky. as far as testing to see if you have power you need to set the multimeter to "V" then probe the negative and positive side of each channel respectively. radio has to be on as well as amp to get results. if you need more help let me know
4x4Hemi
4x4Hemi
Edmonton, Alberta
Oh man that's not good... If its shorted does that mean the amps done?? And as far as wiring it up bridged.. Does that just mean have a wire cutting out 2 of the channels on the sub and and going + to + on the amp and - to -??
4x4Hemi
4x4Hemi
Edmonton, Alberta
They don't pull out!! I yanked on em and can't get em. Even tried gently with pliers
4x4Hemi
4x4Hemi
Edmonton, Alberta
Okay so fuses are good! And I measured the DCv That's wht I needed to measure on the speaker output right? And it says it's 3.1
Zachohs
Archer City, TX
Have you checked the inline fuse from the battery to amp, my amp did this a while back and partially blew the fuse, yet you couldn't tell it, it was still receiving some power just not enough,
Use a multimeter and check at battery and at main power into amp
quietpeen
2021 TRX
Hellcat
exact same thing happened on my 05 and i thought the amp was bad and bought another one. Then replaced the fuse and it worked again. Luckily i was able to sell one of the amps and not lose too much money
olbaid_83
Fort Worth, Texas
you run a single line off the amp....one channel + and the other channel -. if the channels are fried the amp is toast.
4x4Hemi
4x4Hemi
Edmonton, Alberta
I'm bringing it in tomorrow because I've tried so many things. I give up
olbaid_83
Fort Worth, Texas
your input into the amp should be 12v. if you get anything on the outputs of the amp that channel should be good. let us know what it is....ive run into lots of wierd issues with amps.....one way to check if its the amp or not is hook up a known working amp....if it works the amp is your problem....if it doesnt, your wiring or subs is your problem
4x4Hemi
4x4Hemi
Edmonton, Alberta
I don't have a secondary amp to test out, if i did i would do that, I'm thinking its the wiring the guy gave me (its reallyyyy ******) so I'm just going to take my amp and get it tested before i buy new wiring
4x4Hemi
4x4Hemi
Edmonton, Alberta
So what do you think the chances of this guys Sh*thole wiring job is the problem? knuconceptz wiring kit is on its way.
Do you guys think this garbage was the problem?
4x4Hemi
4x4Hemi
Edmonton, Alberta
I didn't pay him. I'm pissed about it though. I said I was going to pick up a 4 gauge amp kit and he said oh I have one you can buy (assuming he meant a new one) nope it was this old ****** one, only paid $40 for it tho but still... Seriously?
TheMaddog
DFW
Check ground, check the amp ground, check sub power, check amp power.
Check to see if you have the subs on, check to see if it's connected to the radio,
Need I go on?
TheMaddog
DFW
Looks like battery connections are ****. I'm running 8 gauge wiring. To match the rest of truck wiring
4x4Hemi
4x4Hemi
Edmonton, Alberta
So the wiring is Stinger, the stuff you get from best buy... Should i replace this stuff? reviews say that its not to bad, and that its 4 gauge. but should i trust it??
Also this is how the dink did the ground
Should ground be 4 gauge as well? because i have more then enough 4 gauge here to make it so. Whats my best bet?
Rambug
Make a 4 gauge ground wire...put a terminal on it so you can screw it to the body of your truck, very close to the amp..within a foot or two. Find a clear area on the body of the truck and ensure there are no wires or gas lines under the truck in that spot. Scrape away all paint in a 1inch area where you chose, and get bare metal showing. Use a self tapping screw, and screw the ground wire terminal to your exposed area and you now have a solid ground. A second option is to use a bolt near the amp. Undo the bolt, clean any paint away and use the bolt to secure the terminaled wire to the body.
4x4Hemi
4x4Hemi
Edmonton, Alberta
Thanks! i just did exactly that... i undid a bolt on the seat, and sanded all the paint, now all i need is a terminal on it, its about a foot long, and will sit right behind my left foot on the drivers side. Should be the perfect spot id think!
Johnnguyen6596
